Author Topic: refilling 020 4 speed tranny.  (Read 846 times)
Offline 2pac
« on: 10 July 2010, 00:35 »
hello
my 4 speed tranny is from 89- does it also have the higher side hole so you can refill entirely through it, or still need to add 1/2 liter from the speedo hole?
thx
Offline raferackstraw
Re: refilling 020 4 speed tranny.
« Reply #1 on: 10 July 2010, 11:59 »
iirc it should have higher hole, if you look at the flat bit where the filler hole is the hole should be offset and not central in the flat bit, if that makes sense, have a look on www.brokevw.com
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline 2pac
« Reply #2 on: 10 July 2010, 13:36 »
bit it's 4 speed, so it looks a bit different.
