Author Topic: Sliding pins in brake calipers...  (Read 1205 times)
Offline twistedblack69
  • Proud mk2 user and abuser
« on: 09 July 2010, 15:29 »
I'm looking at some G60 calipers to upgrade a 16v brake setup, but the guy said they have no sliding pins. He said he thinks that the pins are the same on all or most Girling calipers, can anyone confirm this? Would I be able to use the pins off of 8v or 16v GTI calipers??
Re: Sliding pins in brake calipers...
« Reply #1 on: 09 July 2010, 15:51 »
if you have a 256mm brake setup now the pins from them should work in the 280mm carriers :)
failing that I think you can get new ones from ford, I'll see if i can dig out the infos
edit: here we go, ford rear slider pin but fit front vag carriers apparently. (wont fit vag rears as too long)
F6141154 (pack of 2) £8.00 + vat roughly
« Last Edit: 09 July 2010, 15:56 by rubjonny »
« Reply #2 on: 09 July 2010, 16:09 »
You are a God!! Haha the guy told me I could get them new from Biggred (or something) for about £20. Those Ford ones definitely fit then??
Offline redders
  • 88 8V GTI, 3dr helios blue
« Reply #3 on: 10 July 2010, 00:32 »
yeah the ford ones fit a treat :cool:
