Author Topic: abs light  (Read 1477 times)
Offline ian007miles
abs light
« on: 07 July 2010, 15:40 »
hi every one my mate has a broblem wiv his golf gti 18T agu, when in traffic the abs light keeps coming on and peeping and then the hand brake warning light comes on as well (hand brake is down not pulled up) hes all the brake fluid coz it was full of crap and dirty does anyone no wot it could be thanx ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: abs light
« Reply #1 on: 07 July 2010, 16:05 »
sounds like the wire maybe splitting on the front passenger side part of the loom. Brake pad warning sensor is also part of the same loom.
Not sure about the handbrake light, is he sure its the handbrake light? If its a Orange circle in orange brackets then thats the brake pad warning light
Offline will gti
  • ARZ 1.8T
Re: abs light
« Reply #2 on: 07 July 2010, 18:25 »
i had these lights on and it was because i had split cables on both side
WHEELS IN SIG FOR SALE FERB'D WITH NO CURBING, ALL WITH GOOD TYRES GOODYEAR NCT 5
Offline ian007miles
Re: abs light
« Reply #3 on: 10 July 2010, 15:03 »
had the car plugged in to day no fault codes gona check the wires tomorro :sad: :sad:
Offline ian007miles
Re: abs light
« Reply #4 on: 13 July 2010, 20:04 »
Just looked at the wires but we can't see any slits or cracks in the wires and my mate had it plugged in and no fault codes came up does any one no what else it could be ?????????
Offline will gti
  • ARZ 1.8T
Re: abs light
« Reply #5 on: 13 July 2010, 20:07 »
dunno what that could be then m8....hope you find it tho .
Offline Phil18t
Re: abs light
« Reply #6 on: 14 July 2010, 21:56 »
dodgy level sensor in the brake fluid reservoir?
