Author Topic: I have the following Fault Code's - Help Required Please. No Power !  (Read 4537 times)
Offline johnford60
  • MK7 GTD 3 Door
I have had a fault for a couple of weeks now with intermittent power loss and have another thread open on here about it. t has got worse these last coiuple of days. On the way to my friends how to run VCDS on it i lost all power, I think i lost all turbo power!.
 Faults Found:
000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
               P0234 - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 20
                    Mileage: 145435 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:49:20
             Freeze Frame:
                    RPM: 6653 /min
                    Load: 81.5 %
                    Speed: 130.0 km/h
                    Temperature: 87.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
012403 - Fuel Pump Circuit: Electrical Malfunction
               P3073 - 004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 147682 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:09:09
             Freeze Frame:
                    RPM: 903 /min
                    Load: 25.5 %
                    Speed: 6.0 km/h
                    Temperature: 47.0°C
                    Temperature: 37.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
Hope someone can help me out?
John
John
Offline RTechUK
  • R-TECH OFFICE 01455 617233
You really need to do some logging on the car, log the load and fuel to see what is going on with the requested and what the harware is doing.
Nick
 01455 617233
Offline johnford60
  • MK7 GTD 3 Door
Should I check for vacum hose leak tomorrow first, then data log?
John
