Author Topic: HT Leads & 4 Prong Bosch Spark Plugs  (Read 6612 times)
Offline m4nesh
« on: 11 August 2003, 19:08 »
Hello All!!! Need some advise!
Gonna purchase some HT Leads as told they make a noticable difference and been advised by the chaps at Graham Goode store to buy 8mm MagnaCore or 8mm Diamond HT Leads.  Are these any good and any other suggestions or thoughts.
Secondly, Bosch have brought out a spark plug with 4 prongs.  I've been told if you have a induction kit NOT to use it coz your engine will run too hot and eventually burn out the valves (this is advise from a man from Volkswares stores in Leicester)....Has anyone got an opinion on this??? Should I just stick to standard spark plugs?
Cheers Manesh
Offline m4nesh
Re:HT Leads & 4 Prong Bosch Spark Plugs
« Reply #1 on: 16 August 2003, 22:28 »
come on!!!
No one can offer me advise!!! There must be someone out there who knows there stuff???
Offline tizer2000uk
« Reply #2 on: 25 August 2003, 09:17 »
The standard 3 prong sparkies from VW are more than adequate as are the leads you get from halfords.  This whole spending ?30 on a set of fancy coloured leads in my opinion shows no gains, you see there is I think upto 50,000 volts surging down the lead to make that spark and even a cheap bit of copper (which is one of the best conductors) is going to deliver all of it.
golfvr6
« Reply #3 on: 26 August 2003, 10:26 »
I agree with Tizer. I think standard leads will do the job fine.
Offline kevin
« Reply #4 on: 26 August 2003, 22:50 »
I have to agree also ,recently changed plugs from standard 3 prong to bosch super 4 plugs and car not running nowhere as good ,as for leads i cant fault vw leads or standard bosch replacement part,
regards kevin
golfvr6
« Reply #5 on: 26 August 2003, 22:55 »
Do Bosch make most of the leads for VW?
Offline kevin
« Reply #6 on: 27 August 2003, 03:40 »
not to sure !! but bosch parts are so cheap here,,
the factory is like 2 mile away,and the discount we get ,well,cheap as chips.
regards kevin
bosch leads are o.e spec
« Last Edit: 27 August 2003, 03:46 by kevin »
golfvr6
« Reply #7 on: 27 August 2003, 09:41 »
I'm fairly sure Bosch make all the leads for VW, or most of them!
Offline kevin
« Reply #8 on: 28 August 2003, 01:29 »
GOLFVR6 just a example ,today ordered new leads for a valver ,bosch ,?30
cheap as chips  ;D
regards kevin
p.s the bad bit
they take 3 days to deliver :'(
at that price who cares ;D
golfvr6
« Reply #9 on: 28 August 2003, 14:00 »
Nice one!
