Author Topic: I have the following Fault Code's - Help Required Please. No Power !  (Read 3293 times)
Offline johnford60
  • MK7 GTD 3 Door
I have had a fault for a couple of weeks now with intermittent power loss and have another thread open on here about it. t has got worse these last coiuple of days. On the way to my friends how to run VCDS on it i lost all power, I think i lost all turbo power!. :undecided:
 Faults Found:
000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
               P0234 - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 20
                    Mileage: 145435 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:49:20
             Freeze Frame:
                    RPM: 6653 /min
                    Load: 81.5 %
                    Speed: 130.0 km/h
                    Temperature: 87.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
012403 - Fuel Pump Circuit: Electrical Malfunction
               P3073 - 004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 147682 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:09:09
             Freeze Frame:
                    RPM: 903 /min
                    Load: 25.5 %
                    Speed: 6.0 km/h
                    Temperature: 47.0°C
                    Temperature: 37.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
Hope someone can help me out? :smiley:
John
John
Offline bacillus
Try disconnecting the MAF and see if that makes any difference.
Without traction power is nothing!
Offline johnford60
  • MK7 GTD 3 Door
Disconnect and drive you mean?
John
Offline Hurdy
What mods/tune have you got and have you had any changed recently or service done at VW?
Clue for me would be the loss of electrical signal for the fuel pump. If the ecu spotted this then it would certainly cut power as it would think that you have no fuel supply even if you have fuel pressure.
Seat Leon Cupra Black 290 DSG
Offline johnford60
  • MK7 GTD 3 Door
Ive got a Fuel Pump Control Module coming out today!
John
