Author Topic: Mk2 16V 1200 Idle?  (Read 3277 times)
Offline lingl9z
Re: Mk2 16V 1200 Idle?
« Reply #10 on: 05 July 2010, 21:03 »
http://www.golfgtiforum.co.uk/index.php?topic=99852.0
Its at the top of the MKII section called Maintanance fella!
Cheers for that buddy! I'll Take a look! :)
Offline lingl9z
« Reply #11 on: 05 July 2010, 21:06 »
Idle speed high
1)Check auxillary air valve; where is this and how do I check it?
Ensure that it is closing.
2)Vacumm leaks; - I know how to check for these.
Self explainatory.
3)Check the minimum air; not as self explanitory as it seems!
Self explainatory.
(I'm a bit of a K-jet noob tbh)
Offline clipperjay
« Reply #12 on: 05 July 2010, 21:07 »
Hint most of that is connected to your airfilter box internally and externally!  :wink:
Offline emery1990
« Reply #13 on: 05 July 2010, 21:11 »
gay jet more like! youll get there soon mate,
No he didnt come down and help lol Got to get my flywheel off aswell, thats going to hurt my brain alot as i understand its a gearbox out job  :shocked:
Offline clipperjay
« Reply #14 on: 05 July 2010, 21:15 »
LOL :grin: Yeah but once you get it running sweet you will never look back!
You haven't seen mine? It's in bits and I know it will NOT run right afterwards, untill I tinker with her, so talk to her, she will listen soon or later!  :laugh:
Offline emery1990
« Reply #15 on: 05 July 2010, 21:18 »
yer true!, there isnt even alot wrong with it though, starter motor stalls when cold and runs lean and high idle, nothing major i dont think. Touch wood :D i bet someone with good knowledge could sort it in a n hour lol, its taking me since april  :undecided:
Offline clipperjay
« Reply #16 on: 05 July 2010, 21:32 »
There is a reason why they call it a engineers car!
In my mind when I was a kid I knew nothing, but I know my cars inside and out and TBH if you do a job yourself its done to the letter because you're scared of screwing it up, this means the job was done right you just have to grow a pair and get on with it, but hey to me problems with cars are fun. :smiley:
Offline emery1990
« Reply #17 on: 05 July 2010, 21:37 »
yer true, if i muck up on a job it could kill me!
Everyone goes on a bout how simple the cars are though!
Wish i found them fun lol I get bored of problems from work
Offline lingl9z
« Reply #18 on: 05 July 2010, 21:40 »
Cheers for that buddy :) I'll attempt most things on my cars, one thing I won't touch is the timing belt which I need to get done as the guy before said he had no idea when it was last done so worth doing!  - Any know if these engine's are interferance or non-interferance ? :)
Offline clipperjay
« Reply #19 on: 05 July 2010, 21:51 »
Thats why I'm going to put disclaimers on all my replies to you :grin:
Emery I work on cars to get away from problems with work!
16V timings are more important get it wrong and it will run like a bucket of spanners in your block!
Top tip cut half of the timing belt slip over the new one tension up, cut off remaining belt and your done!
Remember to keeping an eye on the flywheel markers on the gear box aswell!!! :wink:
