Author Topic: k jet system/metering head Question?????  (Read 2673 times)
action al
Re: k jet system/metering head Question?????
« Reply #10 on: 31 December 2004, 11:06 »
Yeah i got a strong spark to each plug and the buzz of the fuel pump is there but when you turn the key it fires once then nothing just the starter trying its hardest. :sad:
As for the flap moving freely it feels kinda spring loaded at the moment and only moves about 1cm
It is spring loaded but should move about 5cm's
If you take the induction pipe off the top and grab hold of the bolt on the flap you should be able to move it without too much trouble to about 5cm's up I think
Anyway just realised who you are, the new one i'm sending you should sort this out! or give you some spares at least!
« Last Edit: 31 December 2004, 11:08 by action al »
Judderi
« Reply #11 on: 31 December 2004, 11:17 »
Ah its you! I should have guessed really.  :grin: Well the one thats on at the moment doesent move that far at all. Doesent even look as if it could! The circular plate is too big to move that high up. Maybee its already too high and should be moving down? Will see when your replacement arrives. Cheers.
Judderi
« Reply #12 on: 04 January 2005, 11:52 »
Sussed it! :smiley: The circular plate had moved and was jammed. I loosed the bolt, centred it and bingo! Nice to have my dub back.
