Author Topic: k jet system/metering head Question?????  (Read 2675 times)
Judderi
« on: 31 December 2004, 09:08 »
I currently cannot get my valver to start. Both myself and a mechanic think that the unit ontop of the airbox (metering head)has failed. Is there any way i can test this? Could i undo the injection pipes then attempt to start the car and see if petrol shoots out? Also if it has failed is it easy to replace or can i strip it down and fix blockages etc. Plus how much should i expect to pay for one?
« Last Edit: 31 December 2004, 09:41 by Mk2GTI2.016v »
VeeDubGTI16v
Re: k jet system
« Reply #1 on: 31 December 2004, 09:27 »
suppose you could pull the injectors out and see if they are squirting :huh: is he talking about the metering head?? i doubt that would fail :undecided: , more likely to be the fuel pump or something like that
« Last Edit: 31 December 2004, 09:35 by veedubgti16v »
Judderi
Re: k jet system
« Reply #2 on: 31 December 2004, 09:40 »
Yeah the metering head. I dont think its the fuel pump because when i disconect the fuel line and turn the ignition fuel squirts everywhere.
VeeDubGTI16v
Re: k jet system/metering head Question?????
« Reply #3 on: 31 December 2004, 10:00 »
well i think the only mechanical bit is the flap that controls the mixture, that could be stiff :huh:
Judderi
« Reply #4 on: 31 December 2004, 10:21 »
There must be more than that. How does it know when to squirt fuel and to which injector? Ive checked the flap thing and i can move it a bit. when i pull it down it sounds like a door bell. Ding!
VeeDubGTI16v
« Reply #5 on: 31 December 2004, 10:28 »
it should move fairly freely, it gets moved by the airflow so should be fairly loose. typically ive just thrown away an airbox 'top'.  :angry:
free
« Reply #6 on: 31 December 2004, 10:32 »
u got spark?
can u hear the fuel pump buzzin when u turn the ignision on
VeeDubGTI16v
« Reply #7 on: 31 December 2004, 10:34 »
if the 'mechanic' didnt check that to start with he shouldnt be a mechanic lol
Judderi
« Reply #8 on: 31 December 2004, 10:45 »
Yeah i got a strong spark to each plug and the buzz of the fuel pump is there but when you turn the key it fires once then nothing just the starter trying its hardest. :sad:
As for the flap moving freely it feels kinda spring loaded at the moment and only moves about 1cm
« Last Edit: 31 December 2004, 10:48 by Mk2GTI2.016v »
VeeDubGTI16v
« Reply #9 on: 31 December 2004, 11:01 »
are the injector seals ok? fuel lines not leaking anywhere?
