Author Topic: Power all over and now traction control light on! I hate my golf!!!!  (Read 3140 times)
Offline topher
  • Administrator
  • fully functioning
the hissing noise will be the wastegate venting as your maf is reading high so the ecu "dumps" what it thinks is the extra air/boost in the system. I would assume the jerking is a misfire as the maf signal is sending dodgy readings but not quite exceeding the upper limit that triggers the 16487 code
Offline Big Tone
Ahh,
I see, Nice one toph!
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Big Tone
not good. fitted new maf and hs still the same. pretty sure all boost hs being vented to wastegate. it sounds like a whirlwind under the bonnet. new n75 new maf. where to next?
Offline topher
  • Administrator
  • fully functioning
did you clear the codes? might be in limp mode
check there isn't a boost hose popped off too because that can sometimes trick the ecu into thinking the maf is dead
Offline Big Tone
I did clear the codes, took her for a spin, same again, less jerky though, more like a smooth hissing/tornado!
Exact same codes came back, but no "17705 - Pressure drop between......." though, just the MAF one!
Will check boost pipes tonight when I am back from work "again" because it does sound like the turbo is producing loads of boost, its just all going to waste.
I will be back.
Offline Big Tone
Re: Power all over and now traction control light on! SORTED!
« Reply #15 on: 06 July 2010, 19:16 »
Well, f*ck me, I have found the problem.
The boost gauge which I fitted at the weekend came with its own length of silicon hose. Which at the time I thought,
"thats a bit soft"
When under vacuum the hose collapses in on itself and kinks over, then when on boost the air to the FPR is cut off/restricted massively. It looked like this thing was alive when revving the engine.
Replaced now with some proper stuff so fingers crossed.
(I say fingers crossed cos i haven't actually taken it out yet :tongue: :tongue: :tongue:)
Offline darren1.8t
  • I HATE FRENCH CARS
i better check mine m8 lol  :grin:
Offline Big Tone
Ha ha, also noticed a bit of a boost leak on the charge to pancake pipe, going to ditch the cr*p o ring/c clip arrangement and fit a silicon reducer!
