Author Topic: how to check gearbox oil  (Read 6085 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: how to check gearbox oil
« Reply #10 on: 03 July 2010, 18:52 »
looks rather autodataish rmachines lol
Damn you caught me!   :grin:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline jocarl11
« Reply #11 on: 03 July 2010, 19:05 »
Misky on the 16v (02A gearbox) it's the 17mm hex on the top left diagram Rmachines sent you. If you look under the car from the front you will see it on the gearbox right infront of you.
Carl.
« Reply #12 on: 05 July 2010, 09:21 »
i fill em thru the speedo sensor/cable hole on the top, much easier.  level checking as per normal though, remove filler plug and fill till it starts to come out, refit bung and sensor/cable job done.
tip, i cut the bottom off an old gearbox oil bottle, stuff the other end into the speedo sensor hole and makes a great funnel
Offline Misky
  • MK3 16v GTI FTW!!!
« Reply #13 on: 05 July 2010, 09:26 »
Cheers guys! Problem solved!
Jonny - I have a funnel with some hose pipe attached as the R5 GTT was a right pain.  :laugh:
MK3 16v GTI FTW!!!
