Author Topic: gearknob shaking!!  (Read 1210 times)
Offline shazz290
gearknob shaking!!
« on: 03 July 2010, 13:47 »
bought a golf 4 months ago which had needed a gearbox soon which was included in the sale.  It doesn't go into gear one without coming to a stop or sometimes doesn't go in at all but for the last couple of days when in gear 5 the gear knob is shaking and sometimes in gear 4 and the car is vibrating at high speeds.  its like i can feel every bump on the road road
is this more symptoms of the gearbox being knackered or something else?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: gearknob shaking!!
« Reply #1 on: 03 July 2010, 15:58 »
Unless there is a nasty grinding noise with the vibrations its unlikely to be the gearbox internals!  Possibly drive shaft issues but most likely engine mounts or something along those lines.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
« Reply #2 on: 05 July 2010, 09:18 »
id go with the box mount, if you check it out and see oil everywhere around it thats a sign that it is dead.
