Author Topic: Fuel filler panel rusty  (Read 1668 times)
Offline doopydug
« on: 29 December 2004, 22:22 »
Is this serious
Couple o wee holes forming below the fuel filler cap.
You can clearly see them when lifting the filler cap cover to refuel - never noticed them before - is it an easy fix or am I in trouble?
Re: Fuel filler panel rusty
« Reply #1 on: 30 December 2004, 16:37 »
What car is it?
Offline doopydug
« Reply #2 on: 30 December 2004, 22:58 »
MK2 16V 1990
Offline Dragon6
« Reply #3 on: 31 December 2004, 18:20 »
Not too serious if caught early and easy enough to fix, but check the inner skin behind this area as that where it may be coming through, its where all the craps been sat over the years lodged between the filler/breather pipes for the petrol tank,Also whilst youre there prise out the metal circlip from around the rubber filler pipe,and pull the neck downwards and have a prod about above this have seen a few mk2`s  start to rot here (top of the filler as you look at the car on the inside it means dropping tank to repair properly)
Offline Gambit
« Reply #4 on: 04 January 2005, 13:32 »
aye id get lookin in round the inner skin. thats where my old 16v went. couldnt see anything on the outer skin around the fuel filler but pushed my hand thru the inner skin on close inspection!!
« Reply #5 on: 05 January 2005, 12:09 »
While you're looking make sure the drain hole at the bottom of the filler area is clear :)
Offline marcogolfo
  • Freelance Web Design, Logo Design etc email me
« Reply #6 on: 20 January 2005, 18:51 »
hmmmmm theres a hole at the bottom? of the  filler area?? ?I had to have a whole rear panel replaced because a plastic arch dropped off and it had rusted to hell, was gonna just repair the arch but when i looked under the filler cap the whole panel had started going
its alright now though with its new panel, you can't even tell :)
« Reply #7 on: 20 January 2005, 19:04 »
Yup theres a little drain hole at the bottom to let the water out  :smiley:
