Author Topic: 00575 - Intake Manifold Pressure  (Read 6159 times)
Offline DarkGti
« on: 02 July 2010, 18:01 »
got this up today can anyone shed any light on this as theres 3 different variations of this code, ive had a new turbo, new MAF, new n75 valve and checked for boost leaks
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 00575 - Intake Manifold Pressure
« Reply #1 on: 02 July 2010, 19:38 »
speak to Nick about this one mate as I had the same code, I think it was mainly down to my intercooler not having enough cold air to it and subsequently getting too hot
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #2 on: 02 July 2010, 19:47 »
Down to driver error...lol
The code could be related to the ecu seeing too much load, too little load or a uncontrolled deviation of load. First you need to know how the load is seen,  Injested air mass is calculated from MAF value (mass/time) divided by RPM (1/time) to yield a mass. Standard mass is calculated by engine displacement (volume) divided by standard density (mass/volume).  The correction which offsets the maths are air intake temps and and alltitude.
If your boost is about the same as it was when you left here, then your fault could be due to a naff sensor reading, or air being drawn in after the MAF.  Check your tip connection to the turbo inlet, and clean the AIT sensors and see how it goes.
 01455 617233
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 02 July 2010, 20:48 »
also mine was pinking its t!ts off lol
Offline Grand Master Patch
« Reply #4 on: 02 July 2010, 21:35 »
How is your running now wazzzer?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 02 July 2010, 22:56 »
still very laggy  :sad:
I've just ordered the new MAF so will see how it feels after that. If my limited knowledge understood Nick properly my current MAF is over reading the air going in...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Offline RTechUK
« Reply #7 on: 03 July 2010, 11:32 »
And the actuator is not playing ball, the mount is bent. :wink:
 01455 617233
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 03 July 2010, 12:06 »
yes that was the biggie  :embarassed:
Offline RTechUK
« Reply #9 on: 03 July 2010, 12:55 »
Which way are you going with it? Forge or oem?  The Forge work well with the red spring and the R-tech-ko3s map, plus yours has some low load tweaks which at the momnet aint working as they should, but when all is 100% the car should respond really well/
 01455 617233
