Author Topic: Rust Busterr  (Read 1635 times)
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
Rust Busterr
« on: 02 July 2010, 14:15 »
right ive just grinded away some rust on my dented wing as a bit of practice
all went well, primed it and sprayed it flash red like the whole wing is, but the bit i sprayed is like a matt not flash
how do i get the shiny sort of finished the rest of my car has??
thanks in advance
kells
Re: Rust Busterr
« Reply #1 on: 02 July 2010, 14:33 »
what paint u using ?
u need to give it its clear top coat? u done that ?
Offline VR6_Wherry
Re: Rust Busterr
« Reply #2 on: 02 July 2010, 14:37 »
+ 1 needs laquer  :cool:
Offline tobybrennan
Re: Rust Busterr
« Reply #3 on: 02 July 2010, 14:43 »
halfords mix up, err done 2 coats primer and 3 flash red and 2 laquer
doesnt seem to be even close to glossy though =/
nothing worse that having a car that doesnt colour match
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
Re: Rust Busterr
« Reply #4 on: 02 July 2010, 16:10 »
flatted after each coat then wet colour flatted after the last colour coat?
+ good machining polishing, out of cans you will never get a perfect finish
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline tobybrennan
Re: Rust Busterr
« Reply #5 on: 02 July 2010, 16:11 »
may sound stupid but whats flattered? x
Offline zdebx
Re: Rust Busterr
« Reply #6 on: 02 July 2010, 17:59 »
Sanding down with high-grade sand paper, like 2500 or 3000, between spraying/laquering.
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline tobybrennan
Re: Rust Busterr
« Reply #7 on: 03 July 2010, 19:29 »
managed to get hold of a machine polisher :)
Offline Jack3559
Re: Rust Busterr
« Reply #8 on: 04 July 2010, 13:20 »
+2 Laquer
You might just need a clear coat.
Halfords sell that stuff too.
Offline boneybradley
  • Back in a Mk3...
Re: Rust Busterr
« Reply #9 on: 04 July 2010, 19:18 »
aero lacquer never gives a good shine... you need to put it through a gun to get any where close to gloss look
