Author Topic: help no brakes  (Read 1122 times)
Offline golfgar
  • Audi A6 estate/subaru wagon
help no brakes
« on: 02 July 2010, 13:35 »
A mate of mine has just done back brakes on a mk4 1.6 v reg,he had to take the calipers off to get them wound back in,now hes put it back together when he bleeds them,they pump fluid through but he then loses all pressure brake pedal goes to the floor,hes checked the system for leaks and there isnt any?? any ideals?
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: help no brakes
« Reply #1 on: 02 July 2010, 13:49 »
has he put the calipers on the right way around/on the right side? Has he split the Piston seal in the caliper? Still air in system?
Offline 2001gti4
Re: help no brakes
« Reply #2 on: 02 July 2010, 13:50 »
I had this years ago on a Capri and the brake servo was shot
My Golf is dead but at least I have this....
Offline golfgar
Re: help no brakes
« Reply #3 on: 02 July 2010, 14:13 »
no air in system,calipers on the right sides,no leaks as i said he also has no handbrake???
Offline Steve_PD
Re: help no brakes
« Reply #4 on: 02 July 2010, 14:18 »
hasnt bled the brakes properly. had this problem when doing the rear beam bushes. need to bleed the system in the correct order
dellenty69
Re: help no brakes
« Reply #5 on: 02 July 2010, 15:15 »
on the SERVO is a bleed nipple (hehe yes a nipple)...
undo it, air will escape, slowly press the brake pedal to the floor and hold it there, and do the nipple back up. same thing happened to mine when doing my rear brake.
james
