Author Topic: 1997 golf gti brake disc problem  (Read 1902 times)
Offline 3000GT ant
« on: 02 July 2010, 11:19 »
Hi guys, i'm currently doing a golf gti up for my friend but we have run into a problem. The car needs a full set of brake discs and pads. I have looked on ebay and found some that i think will fit?? the diameter of the old ones on the front are 288mm with 5 studs, so i asked the seller a question, and they came back with 'these brakes are for golfs with ATE braking system so if yours are ATE they will fit'. To check i type the reg into eurocarparts.com and select brake discs they are suggesting a four stud pattern????
can anyone confirm whether mine are ATE??
If anyone can help that would much be appreciated.
P.s very good site for info i've found doing this car up a doddle now  :wink:
cheers
Ant
Offline VR6_Wherry
Re: 1997 golf gti brake disc problem
« Reply #1 on: 02 July 2010, 13:57 »
I thought ATE were a manufacturer?  :huh:
« Reply #2 on: 02 July 2010, 14:00 »
1997 should be 288 and 5 stud, ATE makes no difference, VW used a few makers at the time.
Offline Dan_GTi8v
« Reply #3 on: 02 July 2010, 14:01 »
ATE is a manufacturer :P I suggest not buying from him lol
When I did mine I looked on eurocarparts and they listed all kinds of discs that wouldnt fit my car (even with the reg) but when I went in they knew exactly what I wanted.
The disc they supplied me with are listed on their site as a vr6 disc. I drive a 8v GTi
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.8_1998/p/Car-Parts/Brakes/Regular-Service/Brake-Discs/?104440351&1&338a6c980753859e13a1de4b8cef68057c0df273&BDIS
Offline VR6_Wherry
« Reply #4 on: 02 July 2010, 14:02 »
+ 1 that's what i was thinking!
Offline VR6_Wherry
« Reply #5 on: 02 July 2010, 14:04 »
Haha i meant, i thought they just made parts, but from what they seller said it sounded like he meant it's a specific system that's not compatible with any other parts. If that makes sense?
« Reply #6 on: 02 July 2010, 14:11 »
All the same to be honest as long as they are 288mm and mk3 offset.
Offline Dan_GTi8v
« Reply #7 on: 02 July 2010, 14:14 »
lol yeah sorry my comment was directed at the op about the guy on ebay :)
Offline Paul86S2
« Reply #8 on: 02 July 2010, 18:04 »
The majority if not all the calipers made for the MK3 288 disc brake system were by ATE. So the supplier is right. If you have ATE calipers you have 288mm discs. Don't what ever you do buy ones listed for the MK4 because they have the wrong offset.
Paul
Offline 3000GT ant
« Reply #9 on: 05 July 2010, 08:41 »
thanks alot guys! ordered the right ones, but the dumbass in the shop, give me 256mm pads??? so now i have to go back today and swap them! when its done i'll post some pics up of it.  :wink:
cheers
Ant
