Author Topic: SMIC piping  (Read 1736 times)
Offline Mikemk4
SMIC piping
« on: 01 July 2010, 18:07 »
Im putting the SMIC back on my 1.8T and ive got the following piping  plus the one from throttle body to intercooler. .
Is this all i need? Or are there any more?
Thanks
Offline vwfiend
Re: SMIC piping
« Reply #1 on: 01 July 2010, 18:24 »
There should be a cheeky sleeve that goes on the outgoing side of the pancake pipe iirc
Offline Mikemk4
Re: SMIC piping
« Reply #2 on: 01 July 2010, 19:07 »
Dont suppose you have a diagram or a rough drawing how it goes do you mate? . . i have bits of odd pipe laying about but i cut the originals and gave some away when doing my FMIC.
Offline vwfiend
Re: SMIC piping
« Reply #3 on: 01 July 2010, 19:40 »
I don't have a diagram mate and the bits I took off mine are at a friends. Sorry pal. I just remember that sleeve on the pancake behind the drivers wheel. When I did my front mount everything back from the pancake was kept original, I only had to take out the side mount which was twinned with the pancake pipe via the sleeve then the pipe going to the throttle body from the side mount I think......
Offline Mikemk4
Re: SMIC piping
« Reply #4 on: 01 July 2010, 19:57 »
Ok mate thanks for your help  :smiley:
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: SMIC piping
« Reply #5 on: 02 July 2010, 08:51 »
Looks like your missing 1 hose that goes from pancake pipe to IC. Its only a short joiner hose
Offline Mikemk4
Re: SMIC piping
« Reply #6 on: 02 July 2010, 10:07 »
Ok thanks mate, i have a few bits of pipe laying about in garage, do you think that would do it? or is it a special chape or anything, also the metal bit on the end of the pipe in my picture, what does that attach to? thanks
Offline Hulmie
Re: SMIC piping
« Reply #7 on: 02 July 2010, 10:11 »
that'll bolt up somewhere to hold it in place, think underside of the wing. You will get more of an idea when its all in place and you will see a hole.
Pipe is nothing special, just a straight joiner pipe only about 2 inch's long.
Offline Mikemk4
Re: SMIC piping
« Reply #8 on: 02 July 2010, 10:43 »
Ok mate cheers  :smiley:
Offline northeast_gti-t
  • "1.8T AGU"
Re: SMIC piping
« Reply #9 on: 03 July 2010, 00:33 »
if you want to pm me your address etc i can let you have that hose you require as i won't be needing it also the two jubilee clips the clips and the hose are near enough new been on the car about 7-8 weeks  :wink:
2000 Mkiv GTi 1.8T AGU
