Author Topic: can i fix this poor finish  (Read 1945 times)
Offline vrsix
« on: 01 July 2010, 02:17 »
my wings have been replaced and/or painted at some point.  the finish is okayish, but in some areas you can see the sanded filler.  you know when you can see the directions of the sandpaper.  hitting this with some wet and dry won't help will it..... the more i think about it i'm thinking it's more likely to be a pattern under the laquer so 'no' is maybe the answer.
Offline dom
  • Back in a Mk4
Re: can i fix this poor finish
« Reply #1 on: 01 July 2010, 10:19 »
Thats a poor prep job then, you shouldn't be able to see the filler at all, let alone sandpaper marks.
Your best bet is to sand it down again but take your time and do it properly, use a very fine grit paper to remove any marks from previous sanding. Any tiny imperfections in the filler will show through the paint.
With bodywork it's all in the preparation, I recently removed some rust from the bottom of my doors and front wing, and it took me a week to do it all. About 1/2 a day was grinding the rust out, 3 days filling & sanding until it was perfect, and then a day spraying.
Here's a link to how i did mine:
http://www.golfgtiforum.co.uk/index.php?topic=147378.50
It starts about 1/2 way down that page and goes on for a couple of pages with a few pic  :cool:
