Author Topic: Front tyre eater !  (Read 4499 times)
Offline Kerrse
Front tyre eater !
« on: 30 June 2010, 15:52 »
How often do most of you change your front tyres ? i seem to be going through a set every 10 months not cheapo's either just cost me another £260 for 2 tyres today.
I am hoping now i have changed the track roads and the lower arms that this set will last a little longer  :cry:
Offline Rhyso
Re: Front tyre eater !
« Reply #1 on: 30 June 2010, 16:06 »
Set of Falkens lasted less than 8K, my Goodyear's lasted about 10K and at the moment my Vredstein's seem to be ok
Offline asif
« Reply #2 on: 30 June 2010, 16:15 »
That's quite a bit of rubber your chewing mate, I guess that it should bee ok now with the work you've had done.
When your tyres had reached the end of there life were they evenly worn?
Also what is your common driving style? Do you hammer it round bends most days?
If your tyres are unevenly worn then your tracking may be out in which case a 4 wheel laser tracking session would do your car some good.
Just a few thoughts of possible reasons for tyre eating.
MK7 GT Bluemotion Tech TDi 150
Offline Rhyso
« Reply #3 on: 30 June 2010, 16:23 »
is that directed at me or Kerrse??  :huh:
I'll answer anyway haha
Falkens were sh!t - Steve will back me up on that lol
All my tyres have evenly worn bar the Goodyears but that was down to the camber being slightly out on one side which has now been corrected
Driving style - normally sedate except for last Sunday........
With regards to Kerrse - what sort of pressures are you running??
 :smiley:
Offline asif
« Reply #4 on: 30 June 2010, 16:38 »
It was directed to Kerrse, but no probs you answering as the more info the better :)
Offline Steve_PD
« Reply #5 on: 30 June 2010, 18:52 »
my car gets through a set of front tyres every 4 months :lipsrsealed: they last around 10-14k depending on make and type of compound. rears last around 20k
as for the falkens :lipsrsealed: ok in the dry, terrible in the wet and extremely bad when 2/3rds worn :lipsrsealed: :lipsrsealed:
80% of my driving is motorway driving sat at 70mph
Offline asif
« Reply #6 on: 01 July 2010, 08:58 »
Do you guys swap fronts for backs to alternate tread wear?
My old mechanic used to do this on services apparently so the tyres get even wear front and back and last a tad longer.
Offline Kerrse
« Reply #7 on: 01 July 2010, 11:52 »
i run all 4 wheels on 32-33 psi i am still on the same back tyres i have had since i bought the wheels new this will be my third set of front tyres inc. the ones they came with. The first set came on the wheels they were avons the last 2 sets i bought were Bridgestones.
They wore down the inside on the last 3 sets of fronts even though i did get my tracking done on a regular basis hence the reason we have changed the track arms and the lower arms.
Offline asif
« Reply #8 on: 01 July 2010, 14:24 »
In that case hopefully what you have changed will be the problem of the uneven wear on your tyres.
So would it have been a case of your wheels were just sitting at the wrong angle before? Or could your camber or toe be out previously? Not sure if it's camber or toe that would cause this as I can never remember which is which :grin:
Offline Kerrse
« Reply #9 on: 01 July 2010, 16:51 »
The the alignment wasn't holding from what i know last time i had it done it was -4 out each side i am the same as you can never remember which is which lol
