Author Topic: Intermitant power loss on GTI  (Read 5071 times)
Offline Davey
« on: 30 June 2010, 10:13 »
Hi, I have a little problem on my 07 GTI. 95% of the time it's fine but occasionally when I floor it, it just dosnt have the normal power. It feels like there is no turbo boost. When this happens, if I lift off fully and then floor it again the power is back to normal.
Any ideas what the problem is? I know it's not the PCV as I had that replaced last week due to a different issue and this problem existed both before and after the new PCV was fitted.
I'm suspecting maybe a sticky diverter valve but that just a guess!
Thanks
Dave
Offline FamilyDub
Re: Intermitant power loss on GTI
« Reply #1 on: 30 June 2010, 11:14 »
Sounds like the DV. Mine was the same.
Get the revision 'D' piston-type valve fitted. They are ~£45 from stealers. Others might recommend the Forge item, but it's more than double the price and unless you're seriously tuned (or intend to be), then the OEM part is perfect.
Part Number 06H 145 710 D
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #2 on: 30 June 2010, 11:33 »
Thanks
Dave
Hello,
Have you checked for any fault codes?
Nick
 01455 617233
Offline Davey
« Reply #3 on: 30 June 2010, 18:43 »
Hi, any idea how much they are fitted? Local VW stealer wants £49 just to diagnose the problem so it might just be worth replacing on spec!
Offline Davey
« Reply #4 on: 30 June 2010, 18:48 »
Hello,
Nick
[/quote]
No, I'm trying to avoid paying the local VW stealer the £49 they want just to diagnose the problem!
Offline RTechUK
« Reply #5 on: 30 June 2010, 19:03 »
Hello,
Nick
[/quote]
Doh!! :grin:
I am only 2 mins down the road and I offer members FREE diagnostics,  Take the trip down the M69 anytime or the next time I am over the inlaw at Cov I will PM and pop to see you. :wink:
 01455 617233
Offline Davey
« Reply #6 on: 30 June 2010, 20:35 »
Doh!! :grin:
[/quote]
Great, thanks. A little more than 2 mins as I'm in south Cov but I'll pop over to you some time over the next day or 2.
Dave
Offline Davey
« Reply #7 on: 02 July 2010, 17:40 »
Thanks for the checkover today Nick. Have now filled up with decent fuel so will see how it goes over the next couple of weeks.
Dave
Offline RTechUK
« Reply #8 on: 02 July 2010, 20:01 »
Dave
Kepp me updated,  You should start to feel the midrange power getting stronger as the ecu adapts the timing advance as it gets used to the fuel.
Nick
 01455 617233
Offline FamilyDub
« Reply #9 on: 06 July 2010, 13:22 »
No idea, but there are several guides on the t'interweb on how to DIY it.  My garage said 'ten minute job, mate'.
It's only about 3-4 torque screws, but the DV is buried on the o/s, near the bottom and you need axle stands to be able to reach it. I don't, so I got it done at the same time as another 2-3 niggly jobs.
Has the checkover sortethe issues you were having?
