Author Topic: Damn windows!!  (Read 4528 times)
Offline N900 MJT
Damn windows!!
« on: 29 June 2010, 22:42 »
Hi guys need some help!
Well after my drivers electric window decided to snap the wire I have replaced the whole mechanism - that was fine and fairly easy!
My problem now is the fact that I have lost one touch up!! When I push the button down the window drops all the way to the bottom no problem but when I press up the window goes to about half way stops the drops almost all the way down - either that or it goes almost all the way up, then with 2 inches to go then drops all the way down again.
Has anybody got any ideas on what I can do to get it back to one touch?
Mitch
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
Re: Damn windows!!
« Reply #1 on: 06 July 2010, 13:39 »
if its falling back down its not a loss of one touch, there's something wrong with the regulator or motor
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline N900 MJT
Re: Damn windows!!
« Reply #2 on: 06 July 2010, 14:59 »
It doesnt fall down it 'rolls' back down as if i had pressed the button again!
Offline MotorPsycho
Re: Damn windows!!
« Reply #3 on: 10 July 2010, 09:55 »
check the wiring, or could be a faulty switch
Offline pauld_88
Re: Damn windows!!
« Reply #4 on: 16 July 2010, 11:01 »
it thinks its being jammed u need to reset the windows i ahve done it in the pasdt but cant remember now i think its something to do with putting key in lock and setting them all down holding for 3 seconds then key in door lock setting them all up by rolling key right and holding 3 seconds then lock car unlock and key in ignition should solve it but dont qoute me on it, its been a while since ive attempted it again.
www.m25dubs.com
Golf Mk3 GTI 8v - sold
Audi a4 1.8t QUATTRO (B6)
Offline 4thQuarter
Re: Damn windows!!
« Reply #5 on: 16 July 2010, 16:15 »
thanks for this info, i will give it a try as i fitted a new mechanism and although the one touch worked both ways i had to press up for it to go down and down for it to go up. All wiring looked ok so its a bit strange!
Offline WeekendMechanic
  • Golf MK3 GTD
Re: Damn windows!!
« Reply #6 on: 20 February 2013, 17:21 »
Does this work can someone confirm?
Offline sharki786
  • GOT BOOST??
Re: Damn windows!!
« Reply #7 on: 21 February 2013, 09:31 »
The symtoms that he has described are the window is not fully aligned. You need to loosen the brackets holding the window just under finger tight, close your window, back down (hold the glass gently) back up and bring down abit and tighten the nuts. Try opening your window all the way and if it sticks repeat the above. I also recomend greasing the feck out of the cables.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline GOLF-MK3-GTI
Re: Damn windows!!
« Reply #8 on: 21 February 2013, 13:33 »
^^^^^ This  :wink:
Gavv8
Re: Damn windows!!
« Reply #9 on: 21 February 2013, 17:59 »
Mine does this on the driver's side, replaced the switch and motor/regulator and it still does it occasionally, i just live with it now.
