Author Topic: Drop Link Bolt Snapped  (Read 4513 times)
Offline perd999
« on: 29 June 2010, 21:15 »
Guy and Girls,
Took off my passenger drop link , putting it back on and tightening the lower bolt abit too much and it snapped!  :undecided:
Will it be alright to drive? Also does anyone have the part no. for a replacement bolt (think it was 16mm)
jamie16v
Re: Drop Link Bolt Snapped
« Reply #1 on: 29 June 2010, 21:20 »
can you or have you already got the old bolt out?. and yes it should be o.k to drive as long as you take the drop link off and take your time. you might find it a bit sketchy as in the front end will want to steer more.. i did this when i had my saxo (big mistake, i let my e36 320 coupe go for that lump of cheese)
Offline perd999
« Reply #2 on: 29 June 2010, 21:31 »
cheers jamie, Half the bolt is still snapped in, ill remove the drop link completly, so it will be ok to go on the motorway?.... bolt part no's?
jamie16v
« Reply #3 on: 29 June 2010, 21:33 »
not sure of part numbers, as i said take your time and its at your own discretion.
you will notice it turn in alot quicker.. (its fun really) :laugh:
Offline perd999
« Reply #4 on: 29 June 2010, 21:36 »
haha, will take it steady....now wheres that drill to get the rest of the bolt out!
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #5 on: 29 June 2010, 21:39 »
if there is abit of the bolt still hanging out after removing the drop link then get a pair of pliers on it and turn it out. If you drill it you may have to rethread the hole which can be a pain in the arse
Offline Steve_PD
« Reply #6 on: 29 June 2010, 21:42 »
use molegrips instead of pliers, heat it up if it doesnt want to move
think its M8 bolt
Offline perd999
« Reply #7 on: 29 June 2010, 21:52 »
its snapped flush  :cry:
Offline bobbarley
  • I'm kind of a big deal...
« Reply #8 on: 29 June 2010, 21:54 »
The bolt fell out of one of my drop links once, I was driving on it for a month before I realised what it was!!  That included both motorway and country roads, doing some speed!
Offline Steve_PD
« Reply #9 on: 29 June 2010, 22:15 »
your going to have fun then :lipsrsealed:
