Author Topic: Single flywheel + VR6 Clutch conversion?  (Read 5626 times)
Offline golf-sib
  • Турботазик
« on: 29 June 2010, 21:09 »
Had a search can anyone point me to what I need for a single mass flywheel conversion (such as which flywheel, g60?) as well as the VR6 clutch (presuming it compatible). As I have read a number of guys doing this, but I can't seem to see any part numbers plus everything I need as well as estimated cost, so if anyone can help out, much appreciated as clutch is going out.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: Single flywheel + VR6 Clutch conversion?
« Reply #1 on: 29 June 2010, 21:21 »
You didnt look far mate
Check the maintenance section
http://www.golfgtiforum.co.uk/index.php?topic=87775.0
Offline golf-sib
  • Турботазик
« Reply #2 on: 29 June 2010, 21:30 »
Thanks for that, any advantages in which VR6 clutch I go for?
1.8T AGU..
R135
  24
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 29 June 2010, 21:31 »
Heard nothing but good things about the Sachs clutch, I run the Techniclutch version which is also very good  :smiley:
Offline Hulmie
« Reply #4 on: 29 June 2010, 21:37 »
yeh sachs vr6 clutch and stock G60 flywheel. Benefits are lighter than normal dual mass flywheel which helps with power. You'll never have to replace a G60 single mass flywheel, unlike the standard dual mass flywheel which your supposed to change everytime you change clutch
Offline golf-sib
  • Турботазик
« Reply #5 on: 29 June 2010, 21:43 »
Thanks any advice onwhee to buy the clutch kit's from as that site does not work in the suggested link?
Also in the kit do you get release bearings etc as I noticed I need new bolts?
1.8T AGU..
R135
  24
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 29 June 2010, 21:54 »
new bolts from the dealers, numbers are in the link posted above. Sachs clutch kit from vwspares  :smiley:
Offline golf-sib
  • Турботазик
« Reply #7 on: 29 June 2010, 22:01 »
Thanks
HEad down to stealers soon, VWSpares use to be 10min away I was like no.1 customer there, shame it shut down and merged with one of the other shops it has due to lack of sales in our area :(
Also can you confirm which clutch kit/number it is:
Mk4: (Cannot see a 3.2, so I'm assuming its the 2.8? + which engine code?)
http://www.vwspares.co.uk/g4clutch.php
Mk3:
http://www.vwspares.co.uk/g3clutch.php
1.8T AGU..
R135
  24
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 29 June 2010, 22:47 »
you need the mk3 VR6 clutch
2.8 VR6    Sachs    3000.384.001
looks like they are out of stock, might be worth giving them a call
Offline golf-sib
  • Турботазик
« Reply #9 on: 30 June 2010, 07:11 »
Thanks wazzer, will give them a call and order it in soonish, nothings going right this month, HTC phone broke and not covered in warranty and now clutch  :sad:
1.8T AGU..
R135
  24
