Author Topic: Faults, with no codes  (Read 989 times)
Offline Mk1Macca
« on: 29 June 2010, 12:38 »
Hi all,
A friend of mine has bought a 1.8T AUM and I have some concerns with it. I plugged in a fault code reader (my liquid) and it only came up with one fault code (to do with the coolant, a temp sender change should fix that) - despite the fact the ABS and traction control lights are on on the dash and I know when he drives it the screen mentions brake pad issues.
I cleared the code to see if it would come back, but the lights stayed on.
Anyone got any ideas?
Thanks!
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: Faults, with no codes
« Reply #1 on: 29 June 2010, 15:09 »
Take front passenger side wheel off, and on the strut will be 2 wires, check these to make sure they havent broke, one is ABS and other Brake Pad warning sensor. Common for them to split or break
Offline Mk1Macca
« Reply #2 on: 29 June 2010, 19:49 »
Will check, but shouldn't there be some codes being thrown up? Seeing as the dash is lit up like a Christmas tree...
Offline Mr_Orange
« Reply #3 on: 29 June 2010, 19:52 »
Are the pads needing replaced then?  If the pad sensors are coming on, that's perhaps not considered a fault code by the ECU, just a warning message.  Same as a low coolant message doesn't throw up a fault code?  :undecided:
Build thread clicky
Offline Rhyso
« Reply #4 on: 29 June 2010, 19:53 »
Did the liquid scan ALL the modules?
Offline Mk1Macca
« Reply #5 on: 29 June 2010, 20:35 »
I'm pretty sure it did / does  :undecided:
Offline Hulmie
« Reply #6 on: 29 June 2010, 20:40 »
I dont think the brake pad warning sensor runs through the ECU therefore not giving codes. Instead it lights up a seperate light on the dash.
Mine has been on since last year as i know the wire is split but its never shown a code on vagcom.
