Author Topic: 51 Gti 1.8t problems  (Read 3768 times)
Offline bailey45
« on: 29 June 2010, 07:23 »
I have a 51 plate gti, it has only done 32,000 miles. But recently I have had a few little problems but got them sorted, but now for some reason it only starts when it wants to, I had a new battery in march   But sometimes when I go to start it there's nothing it doesn't even click and all the clock and mile counter just show blank screens, it's annoying because yesterday it started first thing no probs, then when I got to work I parked up let it for 2 mins came back and wouldn't start, but after I had finished my day it started first time again without jumping it! Sorry to ramble on but it's annoying not knowing what it's going to do !
Offline carrington865
Re: 51 Gti 1.8t problems
« Reply #1 on: 29 June 2010, 11:14 »
i had a similar problem to this on a 200sx once.  turned out to be a dodgy starter motor.  the solenoid was sticking.
could be the cause
007p diverter, piper x panel filter, R-tech remap... and the addiction begins
Offline bailey45
« Reply #2 on: 29 June 2010, 14:44 »
Cheers will I need to replace the starter motor or is there a way of cleaning it up?
Offline 2001gti4
My Golf is dead but at least I have this....
Offline bailey45
« Reply #4 on: 29 June 2010, 17:26 »
Thanks for that I will have a look when I get in from work
Offline james2
  • No scammers please.
« Reply #5 on: 01 July 2010, 00:47 »
make sure your battery connections are tight :evil:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #6 on: 01 July 2010, 07:27 »
This is what happened to me, had the same symptoms as you!
Offline Waffs1984
  • Spacers are for chumps...
« Reply #7 on: 01 July 2010, 09:38 »
Could be a loose earth cable, had this problem on one of my old Rovers when i was at uni
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline LazyLunatic
  • MK3 20VT Project
« Reply #8 on: 01 July 2010, 11:46 »
it wouldnt be the engine earth cable cause that would mean it would try and start, slowly die and burn a wire out...
Offline snap-on
« Reply #9 on: 01 July 2010, 21:36 »
ignition switch fault at rear of barrel maybe ? had this on polos . next time it happens you need to check live feeds at starter etc and if nothing then work your way back towards the switch
