Author Topic: some little questions- under tray and pancake pipe *BETTER PIC*  (Read 3781 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
oks been having a problem with my under tray, even on a slightly bumpy roads it was scraping so i ve desired to take it off as it was saging bady
looked pity beet up as in the connections to the car anyway to fix this, as i want to keep the under try don't like the idea of the belts being open to the road and just looks better.
Also been looking at my "pancake pipe" the pipe to the turbo from the intercooler and it looks fooked, could this be why i am getting white smoke oil getting in there ? also i only noteist today that its not always white some times it black when it comes out of the exhaust and then gose white when its out a bit :huh:
I am getting it on a code reader tomorrow at my mates garage to check it out, i am guessing sh!t loads of codes well be kicked up so GET READY FOR A POST TOMORROW LOL
Thanks
« Last Edit: 29 June 2010, 23:10 by godsANGER »
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline Rhyso
Re: some little questions- under tray and pancake pipe
« Reply #1 on: 28 June 2010, 21:07 »
on mine the side pieces are completely shot so i'm going to be ordering some of those (might be a few months yet lol)
get a new o-ring and clip for that connection - take it off and clean it up.  Looks like you've been leaking boost from there?  :undecided:
Offline godsANGER
« Reply #2 on: 28 June 2010, 21:23 »
i was thinking of replacing the hole lot at some point but want to do it on the cheap as always lol, thinking of bogging it together till then just need to lift it up off the floor lol
ill do it tomorrow going to see if the VW up road from my mates has the o-ring in also would that be causing my smoke?
also the o-ring part number is it = 3co 145 117 ?
and the pipe from the pancake pipe to the turbo is that silicon or plastic i never checked when i had it up on the jack.
thanks
Offline Rhyso
« Reply #3 on: 28 June 2010, 21:26 »
thanks
The side pieces are £50 or thereabouts in total so not cheap
Not sure on the part number.  On mine its metal but I know on some TDI's it was plastic  :undecided:
If the o-ring is perished or the pipe loose then yeah it will cause black smoke and loss of performance
Offline godsANGER
« Reply #4 on: 28 June 2010, 21:34 »
thanks
i think ill fix myn, lol
Well its a low level Tdi so well be plastic lol  :evil:
ill give it a good clean, and check it all out tomorrow
thanks Rhyso
Offline Adam
« Reply #5 on: 28 June 2010, 22:19 »
Side pieces are only 24 each from VW so they will be cheaper from TPS. Had to buy one last month.
Down Hill From Here.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #6 on: 29 June 2010, 12:33 »
looking at the pic posted and the covering of oil as Rhys has said you have been leaking boost from there i would guarantee you that you HAVE been leaking boost  :wink: as said fit the relevant parts and clean it all up and you'll be fine
2000 Mkiv GTi 1.8T AGU
Offline godsANGER
« Reply #7 on: 29 June 2010, 12:41 »
Going to sort it after work, is the clip there? i can't see it on the pic
  • "1.8T AGU"
« Reply #8 on: 29 June 2010, 13:03 »
Not 100% sure even looking at your pic due to the amount of oil/dirt on the pipe for piece of mind and also they are pennies i'd just get a new clip anyway also it will have better tension being new whereas the old one will be worn etc etc  :wink:
Offline godsANGER
« Reply #9 on: 29 June 2010, 15:21 »
Going to ring them when i get a second to get one ordered can any one check some part numbers?
O-ring = 3co 145 117
retaining Clip = 1jo 145 769
thanks
