Golf mk4
Wazzzer
Hissing sound when boosting? mk4 gti 180 bhp
Topic: Hissing sound when boosting? mk4 gti 180 bhp (Read 3499 times)
fowler21
veeeeedub
28 June 2010, 20:47 »
MK4 anniversary 180hp.
ive got a forge splitter dv , boost gauge and a bmc airbox the secondary air punp hose it just sitting there and when i boost i get a load hising sound but i cant find where its comeing from .ive checked my hoses and theres no cuts ect any ideas anyone?
Hulmie
White MK4 1.8T AGU K03s
Re: Hissing sound when boosting? mk4 gti 180 bhp
28 June 2010, 21:00 »
ditch the split-r dv and get a 007p. Also you may just be hearing the turbo spool up
fowler21
veeeeedub
28 June 2010, 21:02 »
i fort they where the same thing ?? its around 6k revs sounds like its leaking
Hulmie
28 June 2010, 21:32 »
think the Split-r dv can only be closed off to 70%. the split-r is a part atmospheric, part re-circ valve. A 007p is a full recirc valve.
topher
Administrator
Serious forum addict
fully functioning
28 June 2010, 21:42 »
the spring may need adjusting for the warmer weather - have you tried going through the setup procedure again?
Big Tone
28 June 2010, 21:43 »
I have same issue, gets to and holds just over 2BarA boost on WOT, feel like it should sound different though, think I'm paranoid.
I have 007P, pressure test holds fine.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install, New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
fowler21
veeeeedub
Reply #6 on:
06 July 2010, 18:48 »
found the problem, the turbo pipe to intercooler was hanging off
all i did was refit and it was back to normal:D yay
Lewisf1988-DUB
Here all the time
1.8T AGU
Reply #7 on:
09 July 2010, 16:43 »
dude get that sig sorted
Golf mk4
Wazzzer
