Author Topic: 1.8t subframe  (Read 1367 times)
Offline andyj775
1.8t subframe
« on: 28 June 2010, 19:38 »
are the threads to bolt the lower gearbox mount to the subframe in the same place on every one? reason i ask is that both threads on mine are nackered, so im looking at buying another subframe and cutting out the section i need and welding into mine. tried tap and dies etc with no luck so this is my only option before replacing the whole subframe
Offline andyj775
Re: 1.8t subframe
« Reply #1 on: 29 June 2010, 12:10 »
basically i just need to know if the oval hole in which the lower gearbox mount sits (in the subframe) is in the same place on all models of golf and the threads either side for the 2 bolts?
Offline Rhyso
Re: 1.8t subframe
« Reply #2 on: 30 June 2010, 12:46 »
dog bone mount is the same on all MK4's as far as I know.  i.e. you can fit a mount from the R32 to a 1.4
Offline andyj775
Re: 1.8t subframe
« Reply #3 on: 30 June 2010, 13:34 »
ok, thats what i was hoping for! thanks very much rhyso
Offline Steve_PD
Re: 1.8t subframe
« Reply #4 on: 30 June 2010, 18:54 »
why dont you just swap the subframes instead of cutting and welding the one on the car, surely its going to be easier
Offline nadlad
  • Building Surveyor MRICS
Re: 1.8t subframe
« Reply #5 on: 30 June 2010, 20:01 »
theres about 11bolts i did it on mine it sway easier u can pick a subframe up for 10 quid, any vag one will do mines off a cupra not that it matters
<<<Big Build Thread>>>
Offline andyj775
Re: 1.8t subframe
« Reply #6 on: 30 June 2010, 20:31 »
i looked into swaping the frames,but just thought that swapping it would involve getting everything re-aligned etc.
