Golf mk4
Wazzzer
abs light~~~~~ PROBLEM FOUND~~~~~~~
Topic: abs light~~~~~ PROBLEM FOUND~~~~~~~ (Read 2494 times)
will gti
ARZ 1.8T
28 June 2010, 16:27 »
since installing my fk coilovers the abs light has come up on the dash can it be cleaned out or watever ... any help would be grreat
BOTH CABLES ON EITHER SIDE HAD BEEN RUBBING ON THE EDGE OF THE INNER RIM AND YESTERDAY MY DASH LIT UP LIKE A CRIMBO TREE CHECK BRAKE PADS ABS AND A ! FLASHING AND BEEPING SO TOOK WHEEL OF FOUND THAT THE SENSOR CABLES HAD BEEN MELTED NEARLY IN HALF FROM RUBBED BY THE WHEEL,
Last Edit: 03 July 2010, 11:48 by will gti
WHEELS IN SIG FOR SALE FERB'D WITH NO CURBING, ALL WITH GOOD TYRES GOODYEAR NCT 5
2001gti4
Here all the time
Re: abs light
28 June 2010, 16:47 »
Code reader should be able to tell you exactly what it is and also clear it.
My Golf is dead but at least I have this....
Rhyso
Global Moderator
Sir Postalot
Re: abs light
28 June 2010, 16:48 »
did you disconnect it? Might not have plugged it back in properly or just snagged a wire causing it to short out
Fire Up The Quattro
will gti
ARZ 1.8T
Re: abs light
28 June 2010, 19:29 »
didnt unplug it
didnt really touch it just unclipped it like from bracket
Rhyso
Global Moderator
Sir Postalot
Re: abs light
28 June 2010, 20:18 »
Quote from: will gti on 28 June 2010, 19:29
didnt unplug it
probably a short in the wire mate
Fire Up The Quattro
will gti
ARZ 1.8T
Re: abs light
28 June 2010, 22:22 »
so i wont need a new sensor then ? how do i sort that out then just clear code and reset light isit ?
just had the wheel off then nothing seems to be visably wrong like
northeast_gti-t
Serious forum addict
"1.8T AGU"
Re: abs light
Reply #6 on:
30 June 2010, 11:03 »
Had an abs sensor fault on mine when i changed the front/rear discs and pads did disconnect the brake pad wear sensor mine came up during a vag com scan had a look didn't find anything amiss cleared the code and didn't come back on
2000 Mkiv GTi 1.8T AGU
lemonadeX
Re: abs light
Reply #7 on:
30 June 2010, 14:13 »
Check really carefully along the sensor cable...I damaged mine when fitting coilovers which caused the same warning light.
Will
will gti
ARZ 1.8T
Re: abs light
Reply #8 on:
30 June 2010, 18:07 »
nice 1 for the help had a look at the cable cant see anything but when went for a drive no light for about 20 mins untill i took a right hander at about 40 and then like magic the light came back on
Lewisf1988-DUB
Here all the time
1.8T AGU
Re: abs light
Reply #9 on:
02 July 2010, 14:57 »
Try removing the 3 small fuses from on top of ur battery in the fuse holder and cleaning them and give the fuse holders a little blow, or use a small brush. I had a light on and this advice was given to me and worked. Worth a try
Golf mk4
Wazzzer
