Author Topic: Tyre wear/Tyre pressures  (Read 2037 times)
Offline simonkit
« on: 28 June 2010, 08:33 »
 I've just checked the fronts on my MK5 GTI and there's at least 4mm at the edges but they're nearly down to the wear indicator in the centre, car has done 13500 from new.
 This seems to suggest the tyres (Michelin HP Primacy) are overinflated but I regularly check the pressures and make sure they are at the recommended 36psi, does everyone use the VW recommended pressures?
 thanks
 Simon
Offline TagnuT
  • Edition 30
Re: Tyre wear/Tyre pressures
« Reply #1 on: 29 June 2010, 21:47 »
I just stick to the standard tyre pressure and tyre wear has been even.
Bye Bye Edition 30
« Reply #2 on: 29 June 2010, 22:16 »
Better to stick with standard tyre pressures
Offline FamilyDub
« Reply #3 on: 30 June 2010, 11:11 »
For the life of me, I can't remember what the VW-recommended pressures *should* be, but I run them at 35psi - that's hard enough.
Any higher and I can feel the fillings starting to shake themselves loose.
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline TrickGTI
« Reply #4 on: 30 June 2010, 12:41 »
I run mine at 32 and that feels plenty in my eyes, i have no problems at all with wear and seems to feel better on the road when not as pumped up :smiley:
Offline jaydubveedub
« Reply #5 on: 01 July 2010, 13:15 »
34psi for me (with Michelin PS3's).
Used to run at VW's recommended 36psi but ride was a bit firm for my liking.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline marty341
  • To ko4? or to not Ko4? now that is the question.
« Reply #6 on: 01 July 2010, 13:24 »
Yeah 34psi works great for my setup too. :smiley:
Revo Stage 1
