Author Topic: electric window don't work  (Read 655 times)
Offline ant_gti
  • mk3 20v turbo
« on: 27 June 2010, 21:28 »
hey guys i'm new to the forum and new to golfs sooo please be nice lol. i've had my mk3 8v for about a month now and my drivers side leccy window has stopped working.managed to take the door card off today to find the cable that drives the pulleys has snapped  :angry: what i was wondering is if that  cable is replaceable or is it a whole new leccy window jobby any advice will be much apreciated thanks
Offline Mr.Tom
Re: electric window don't work
« Reply #1 on: 27 June 2010, 22:20 »
Pretty sure it is a whole new mech. If I remember rightly, the wire goes round a drum a few times the is driven by the motor. It is a sealed unit (I may be remembering my old Escort one tho :))
I would check it over carefully tho, as a broken wire could have got jammed up and caused other damage.
It would probably be cheaper and easier to just swap out the unit tho. Get one from a scrappy or ebay for a few quid and it is a nice easy job to swap them out.
Drop the window down a bit (or hold it up as needed) Undo the 2 bolts that hold the window onto the "gripper" bit. I held mine up afterwards with some masking tape (lots). Undo the 3 bolts that hold the unit in. Wiggle it free and undo the electrical connection. I think you have to slide the connector sideways, or part of it.
Reverse the job with the new one. Don't do the gripper up tight onto the window. Close it all the way, then either reach up behind the rather annoying door frame, or carefully wind the window down a bit to tighten the 2 bolts on the gripper. Took me about 30-45mins in the dark for a rear unit first time. Just make sure the glass is in its runners properly, and you have the wires on the right side before you do it up :D
Offline ant_gti
  • mk3 20v turbo
« Reply #2 on: 27 June 2010, 22:32 »
thanks for the reply mr tom i'll have a look about for a new one are they all the same mines a 92 3 door
Offline Mr.Tom
« Reply #3 on: 27 June 2010, 22:41 »
I would have thought so. Can't see why they would make them different (although cabriolet ones may be).
