Author Topic: E/Window stops half way up.  (Read 9429 times)
Offline Nallen
« on: 11 August 2003, 11:28 »
Can someone help me please !!!
Car - Golf GTI III, P-reg 97'
Electric window goes up and down 4 inches but not all the way leaving my window half open.
Picked up replacement motor along with regualtor down the breakers and that worked for 1 week. Except when you pressed the button long enough to go automatically up it kept stopping and going down an inch. You had to press the button 3/4 times for it to close. Today the window is jammed and it won't go up or down.
I can hear a noise which sounds like the motor is trying to work but nothing happens.
Can someone relate to this problem and offer me a cheap solution.
Offline sherbert
Re:E/Window stops half way up.
« Reply #1 on: 11 August 2003, 13:20 »
some how i dont think you are gonna find a cheap solution. Sounds like a trip to your local VAG dealer. NO!!!!!
mk3 gti 16v silver dream machine (Now has nice wheels :) )
Offline seyles
« Reply #2 on: 11 August 2003, 15:10 »
My drivers side window developed a similar problem, wouldn't go up all the way. It would slow down, stop then go down. Had it done at VAG dealer during service, cost about ?500 just for that!
?1200 for the whole service!
Last time I ever went to the dealer!!
They said it was the regulator / window guide.
On the up side, the problem has never come back.
Offline wheelrefurb
« Reply #3 on: 11 August 2003, 17:15 »
 :(  ?500!! Thats really cheered me up! My car goes in to the local dealer this Thursday because I admitted defeat with my drivers side window.
It won't go up or down, and I can't get the motor out because the manual tells you to lower the window to release the glass. Doesn't tell you what to do though if the motor won't work and there is no obvious means to manually wind down the window.
I'll let you know what happens.
Offline tianaroja
« Reply #4 on: 11 August 2003, 20:07 »
i dont know wether this is any use but i changed mine in my mk2 and it was easy and i got the motor for twenty quid from the breakers
i dont think they are a lot different in a mk3
Offline Nallen
« Reply #5 on: 12 August 2003, 09:03 »
Thanks for all the feedback, from checking other forums people have experienced similar problems on their MK 3.
I'll purchase a replacement regulator and hope that does the trick and advise afterwards.
Thanks again !!
Offline Nallen
« Reply #6 on: 12 August 2003, 10:50 »
For those interested in purchasing a replacement regulator.
Breaker - ?35
VW - ?67
Euro Car Parts - ?52.86
All include VAT.
Offline Nallen
« Reply #7 on: 12 August 2003, 11:00 »
VW won't give me a refund if the problem doesn't resolve, where as Euro car parts will (except 25% handling charge).
Why have you had bad experiences with Euro car parts.
Offline modulater
« Reply #8 on: 12 August 2003, 20:35 »
I'm always having this problem on my MK2, I have a total closure alarm and when set the rear window on the right gets stuck half way up, I just normally squirt some WD40 in the window channels and it cures it. I find that after jet washing the car it starts to play up, I have taken the door trim off before and removed the motor and regulator to give a good lubing up, after which the window was flying up and down.
Offline wheelrefurb
« Reply #9 on: 14 August 2003, 21:12 »
I dropped my car off at the ocal dealer this morning with a fair degree of worry about the size of the bill after reading some of the comments. I was very please though to be given a price of just over ?200 to fix my drivers window (new mech) and dash lights (new relay or something).
I was not so impressed at being kept waiting for an hour having turned up at 4:45 pm to see if the car was ready, just to be given a price and told the job would be done by Tuesday.
