Author Topic: does this block look f**cked to you?  (Read 2341 times)
Offline Lee_dub
« on: 25 June 2010, 14:20 »
Heres the box off it
or has it just had a massive oil leak?
Black mk1 2.0 16V - woop
Offline Sam
  • Sam I am
Re: does this block look f**cked to you?
« Reply #1 on: 25 June 2010, 14:58 »
whatever condition it is in you should be stripping it. then you will soon see
Offline Lee_dub
« Reply #2 on: 25 June 2010, 15:25 »
well, i won't be stripping the crank and all that out - too much hassle
Offline Sam
  • Sam I am
« Reply #3 on: 25 June 2010, 20:09 »
well, if you aint prepared to check declare it as f**ked
« Reply #4 on: 25 June 2010, 21:17 »
Does it still turn over.
Offline tomsdubs
« Reply #5 on: 25 June 2010, 21:36 »
Cant tell from pics like that and if the damage is internal how would we know!
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #6 on: 25 June 2010, 22:33 »
I'm guessing that a conrod has not let go in spectacular fashion as there's no unplanned holes in the block. Other than that I have no fcuking idea... :rolleyes: :rolleyes: :rolleyes:
Keeping schtum. Mostly.
Offline Khare
  • The bear that khares
« Reply #7 on: 26 June 2010, 09:05 »
If you ain't bothered to strip it for the benefit of yourself then you should not bother posting on the forum as we can't read into the condition of the block if it's still in one piece!
Offline dan_apps
  • too low for british roads!
« Reply #8 on: 26 June 2010, 10:18 »
u cant tell much from ur pics, has it stopped working? history? basically as above u need to take the head off or get a specialist to look at it if you cant yourself. what are ur plans for it?
Offline JC
  • Back in the North.
« Reply #9 on: 26 June 2010, 10:23 »
more to the point WHY ?   :rolleyes:
