Author Topic: Castle Coombe Friday 25th June  (Read 21749 times)
Offline leeroy20vt
  • h reg mk2 gti
Re: Castle Coombe Friday 25th June
« Reply #40 on: 01 July 2010, 22:50 »
some cool vids and pics there u all got me sh\'t in my self about brakes now lol doin my first trackday on saturday and it only has standard disks and pads did change the brake fluid tho  :lipsrsealed:
Offline RalphW
« Reply #41 on: 02 July 2010, 00:00 »
Taken straight from the EBC site:
Bedding in when the red EBC surface coating (marked on the pads as Brake In) is applied.
Best procedure is to drive gently avoiding harsh braking unless in an emergency for first 100 miles. In the second 100 miles (up to 200) you can use gently increasing brake pressures when using the brakes.
Only after 200 miles urban driving (not 200 miles on a freeway where brakes are almost unused) should you attempt to apply heavy load and heat to the brakes. To do this final bedding on a QUIET ROAD in safe traffic apply the brakes and slow from 60 to 10 MPH five times in a row. Then drive slowly for a few minutes if safe to do so to allow the brakes to cool. Try to avoid coming to a rest whilst the brakes are heated.
A smell may be noticed from the warm brakes, this is normal. Repeat this procedure a second time after the brakes have TOTALLY cooled down. EBC pads get better with miles. Even after this bed in procedure it can take up to 1500 miles before the pads are at their best. In the meantime the pads will be good and safe but true potential not realised. EBC makes performance pads that last, they do not bed in within 5 minutes driving. Noises will be more likely during the first 1000-1500 miles use whilst this chemical bedding takes place.
NEVER attempt to sand or scotchbrite brake pads to assist it bedding in or noise reduction,this will only make things worse by taking the pads "Off-Flat" and require hundreds of miles driving to seat them again during which time the brakes will feel very dull. The only way to seat pads is against the rotor they will be used on and by following our bedding recommendation.
Bedding in for trackday or race use …
We remind you there is NO WARRANTY on any EBC product for race use due to the very varying conditions that can be seen. However, care bedding pads in and monitoring wear will get the best from our products.
Most EBC pads including Yellow range pads now have the brake in coating. If possible and using a street based car, fit the pads before the race use and bed in as above for street use. Try to get 200-300 miles urban driving on the pads before racing them. If this is NOT possible and you fit at the track bed like this.
Drive two laps steadily applying the brakes every few seconds and then coast for a full lap without any unnecessary braking to allow pads and rotors to cool down. Drive a third lap applying the brakes slightly harder each time and again drive a cooldown lap. Do NOT pull up and park the car with the brakes red hot, try to let them cool as much as possible before coming to a rest. It is also important to understand that the pads must be geometrically matched to the rotor (flat and parallel) before they will bed in chemically. If you do the above bed in and get violent fade first use you MUST repeat the bedding procedure. We get lots of new customers calling in saying my brakes have faded and when they send a digital the pad is only touching on 70-80% of its surface area. Fade early in a pads life is almost a good thing. It is called GREEN fade and will disappear so if you suffer Green fade (you will notice this by smell), you are on the right path and this is not a negative. If you are getting fade after 20 laps and the pads are part worn, then something else needs looking into such as material choice, bleeding of the system, driving style etc …
1991 mk2 8v
1988 mk2 16v 2.0 trackcar
VeeDubGTI16v
« Reply #42 on: 02 July 2010, 10:40 »
blimey!
i must be on the 'green fade' procedure at the moment then  :grin:
Offline Paul86S2
« Reply #43 on: 02 July 2010, 17:58 »
Standard discs and pads of OEM quality should be fine. Make sure you drive for the last lap slower to allow them to cool down a bit if there isn't a cool down lap. Some places like airfield days have an are for you to run the car slowly after you come off track.
Don't sit still with your foot on the brake pedal after you stop and don't apply the handbrake, leave the car in gear if you are on a slope and you'll be fine.
Paul
Offline Paul86S2
« Reply #44 on: 02 July 2010, 19:29 »
Short vid from the last session of the day when Justins 944 Turbo span in front of me.
Shame I didn't have a rear camera to watch Nick go across the grass to miss the fun.
http://www.youtube.com/watch?v=7bu1ZPhTcKU
Paul
Offline Horney
« Reply #45 on: 02 July 2010, 22:30 »
Paul
My though process was something along the lines of "AAarrrrgggghhhh brake! Left! Grass! Phew." :grin:
Nick
Offline Paul86S2
« Reply #46 on: 03 July 2010, 00:34 »
Paul
Nick
I'm glad you had time to think :grin:
He was lucky my brakes managed to stop me in time. They were very spongy on that session. At least I think I've found the problem. The front discs are worn into deep ridges / grooves across the whole surface and the pads are the same.
New discs, pads and fluid on the cards for tomorrow if the discs arrive in time.
Bit annoying because the pads are only half worn. :sad:
And the discs are only 2 years old with about 20 trackdays on them  :laugh: I suppose I've had my moneys worth.
Paul
