Author Topic: Castle Coombe Friday 25th June  (Read 21750 times)
Offline Horney
Re: Castle Coombe Friday 25th June
« Reply #20 on: 28 June 2010, 22:30 »
Warning! Low flying Golfs!
http://www.youtube.com/watch?v=eU2qlBUwQMs
Nick
Offline Paul86S2
« Reply #21 on: 28 June 2010, 23:01 »
http://www.youtube.com/watch?v=7r7N_fXZf**k
Correct link
substitute the last f**k for f u k without the spaces
Thanks for the vid. Those two laps had some serious traffic issues. :shocked: I thought we were going to go into the back of that 911 at Quarry when he seriously overbraked early and completely outbaked us (he had the instructor onboard as well). :grin:
Your car appears to be very quick and you definately seem to know how to drive it.
Paul
« Last Edit: 28 June 2010, 23:04 by Paul86S2 »
VeeDubGTI16v
« Reply #22 on: 29 June 2010, 06:35 »
Cheers mate, a session with dave helped a lot. Would like to go back with some working brakes next time! I was using new racing blue as well so might change back to the motul stuff if you were having braking issues as well.
Loving the fly by vid nick  :grin:
Who spotted the elise smoking away in the vid then  :laugh:
Offline Paul86S2
« Reply #23 on: 29 June 2010, 11:35 »
Never had a problem with the Racing Blue in the past, it was very hot at Combe on Friday and the last sessions were only 10 minutes apart.
Just ordered some Motul RBF 600 to put in instead of the Racing Blue, will see how that goes.
Paul
Offline Horney
« Reply #24 on: 29 June 2010, 11:39 »
I had no brake problems all day. I can't have been trying hard enough, ha ha.
Nick
VeeDubGTI16v
« Reply #25 on: 29 June 2010, 14:14 »
The motul stuff is good, i only changed cos its easy to see when the new fluid comes through if its blue lol
I think my main problem was the pads. Maybe i didnt bed them in agressively enough and they have glazed. Ill whip em out and sand off the top layer, change the fluid and see what happens. Otherwise its a waste of £50 and wont be using ebc pads ever again
Offline RalphW
« Reply #26 on: 29 June 2010, 15:26 »
What EBC pads were you using?
1991 mk2 8v
1988 mk2 16v 2.0 trackcar
VeeDubGTI16v
« Reply #27 on: 29 June 2010, 15:39 »
Yellows, which are supposed to be the good ones out of the range
Offline Diamond Hell
  • Opinions я Us
« Reply #28 on: 29 June 2010, 17:26 »
I've always been surprised at just how good the 280mm fronts are with OEM discs and pads.
I guess I don't lap terribly quickly, mind....
After many days at Combe I've never boiled fluid or anything like that.
Mark, are you 280 or 256?
Probably the Syncro system helps a lot in evenly distributing the braking grip, as well as the acceleration grip, too - the system works much more on all four wheels, rather than just on the fronts.
EBC generally = badness anyway....
*shrugs*
Offline Horney
« Reply #29 on: 29 June 2010, 17:57 »
I'm on 256's I think (16v setup right?), Mark is on G60's.
Nick
