Author Topic: faulty vehicle speed sensor  (Read 844 times)
Offline mar_k
« on: 23 June 2010, 17:36 »
i havent got the exact code but thats what is coming up when i scan my 2.0 8v mk4 with vagcom.
it say implausable single - intermittent.
what sensor is it and where is it located please?
Offline mar_k
Re: faulty vehicle speed sensor
« Reply #1 on: 23 June 2010, 17:38 »
forgot to mention i get a slight stutter or hesitation when pulling away
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 23 June 2010, 17:41 »
it's on the gearbox, towards the back
you can get your hand down there to change it without having to remove anything, but check the wiring and try cleaning the contacts on the plug first. Is your speedo playing up?
Offline mar_k
« Reply #3 on: 23 June 2010, 17:44 »
speedo is working fine, just the stutter whilst pulling away,
im using vcds light with an ebay lead,
it wont let me delete the codes after the scan
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 23 June 2010, 18:08 »
it may be a completely unrelated fault (it does say intermittent so may be old) so it would help if you can find someone to clear it for you. A faulty vehicle speed sensor (VSS) shouldn't cause a stutter it only feeds the speedo via the ecu but it may indicate a gearbox issue.
