Author Topic: What the hell is wrong with my wagon? (pics)  (Read 2219 times)
Offline boneybradley
  • Back in a Mk3...
Re: What the hell is wrong with my wagon? (pics)
« Reply #10 on: 23 June 2010, 23:23 »
I would check the wheel hub and the camber (camber being out can make the car pull oddly...and as you've changed bearing twice i would also guess the hub is worn? my old gti went through 3 bearing in a couple of years but had no play)
Offline Jack3559
« Reply #11 on: 24 June 2010, 00:13 »
I'll have to check the hub...
How would I sort out the camber angle? It's that that's off I think...
The inside 3 inches of tire wear off so ridiculously quick.
You can feel the wheel straightening itself up as you go round corners too.
Offline Jack3559
« Reply #12 on: 25 June 2010, 13:21 »
I thought I'd post a video so you could hear the noise, it's loudest in the middle when I'm on the motorway.
http://vimeo.com/12837342
Offline jezza16v
« Reply #13 on: 25 June 2010, 15:25 »
That's the wheel bearing! Water has got into it and corroded the polished surfaces which makes it rough, hence the rumble/drone. You will not detect this by jacking up and trying to move the wheel until the corrosion becomes seriously advanced. Turning left or right loads or unloads the affected bearing.  :wink:
Offline Nino
« Reply #14 on: 25 June 2010, 20:20 »
Yes that defo sounds like the wear bearing to me :)
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Jack3559
« Reply #15 on: 27 June 2010, 11:41 »
So... If it's the unloading of weight does that mean that it's the offside bearing that's gone?
Or would the noise stop as weight is applied rather than removed?
