Author Topic: 00575 fault code  (Read 7125 times)
Offline topher
  • Administrator
  • fully functioning
Re: 00575 fault code
« Reply #10 on: 23 June 2010, 17:58 »
on the inlet manifold next to the throttle body, one 5mm allen bolt holds it in
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #11 on: 23 June 2010, 19:29 »
The AGU ecu works out the boost in terms of load, basedon maths mathmatics displacment, air maf drawn and intake temp =  peak cylinder load or cylinder filling in *ms.  An over reading maf scale will can read as too much boost/load or a AIT sensor fault will offset the readings and still cause overload reading.
The upper limit load cap in our k03s aug maps is set to 11.5ms and the MAF drawn limit id maxxed out.
Do an excell log of the requested boost and actual boost, and maf and post them up, plus make a note of the intake temps.
Nick
 01455 617233
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 23 June 2010, 21:12 »
will do a proper log 2moro when the roads are a bit clearer, damn daytime drivers were in the way today lol
I'll post it up 2moro. Might have your work cut out Nick  :grin:
Just hope nothing is majorly wrong that won't let me get it mapped though  :sad:
« Last Edit: 23 June 2010, 21:16 by Wazzzer »
