Author Topic: Cars not running right again.  (Read 3819 times)
Offline GTI16vGaz
  • New car will be displayed soon.
« on: 11 August 2003, 10:26 »
Hello.....
Has any1 experienced problems with the tick over on a GOLF GTI 8v mk11, i had this problem a while ago so i took my car to the garage n the guy there cleaned the injection system, cleaned the throttle body, my mixture was to rich so he got my mixture to the correct amount... i then picked the car up about 3 weeks ago and its been working fine, no problems at all until last night when i started to get the same problem. Could this be the Idle Control Valve?  ???
Any help would be much appreciated!!
Cheers,
Garry
Offline Lee
  • Oiiii stop your dog sh!tting on my lawn
Re:Cars not running right again.
« Reply #1 on: 11 August 2003, 11:02 »
Hello mate take it off and spray loads of carb cleaner in it till it runs out clear. It should be ok then it worked on mine.
Ape shall never kill ape
Offline richandhazel
« Reply #2 on: 11 August 2003, 11:09 »
I assume you have the Digifant fuel injection system, in which case it could well be your ISV.
Have a look here:-
http://20v.org/engprob.htm#isv
Its Audi, but the same rules apply to this particular component.
This may also help:-
http://homepage.ntlworld.com/richandhazel1/ISV/index.htm
Offline GTI16vGaz
« Reply #3 on: 11 August 2003, 11:59 »
Thanks every1!!!!
I'll give it ago when i finish work today.
cheers again  ;)
Offline GTI16vGaz
« Reply #4 on: 12 August 2003, 13:21 »
richandhazel - check you email!!
I've just let you know the out come of what i tested.
Thanks for the advice!! ;)
Garry
« Reply #5 on: 12 August 2003, 13:45 »
Just read the mail.
Glad you got it sorted and that we were able to help.
Offline wayneprice
« Reply #6 on: 08 September 2003, 22:21 »
Hello.....
Cheers,
I had problems with mine and I've replied to several who've had fuel problems with my experience. I changed every sensor and valve you can think of as well as a proper VW setup but no change. I went back to basics and checked the fuel filter. It was totally clogged. Being an old car there was loads of muck in the fuel tank and was constantly clogging the filter. I flushed out the tank and replaced filter. It now drives like a dream. I hope it helps because I know how you feel
Garry
