Author Topic: New cluster new fault codes  (Read 2264 times)
dub-mike
« on: 22 June 2010, 15:59 »
I installed a immob3 cluster into my golf which had immob2, no problems there but when i ran vag com i got these 4 codes and not sure if they are related or ive done something when ive installed them? car has ran fine for over the week new cluster been in and even coded a new key for the missus to use, can anyone help
cheers
Address 01: Engine
   Controller: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR HS D02
   Coding: 04000
   Shop #: WSC 00028
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 17: Instruments
   Controller: 1J0 920 926 AX
   Component: KOMBI+WEGFAHRSP VDO V23
   Coding: 06404
   Shop #: WSC 00050
   WVWZZZ1JZ3W515276     VWZ7Z0C6933303
1 Fault Found:
01336 - Data Bus for Comfort System
            49-00 - No Communications
Address 19: CAN Gateway
   Controller: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00221
2 Faults Found:
00778 - Steering Angle Sensor (G85)
Offline Rhyso
Re: New cluster new fault codes
« Reply #1 on: 22 June 2010, 16:02 »
Probably came up when you installed the cluster
Clear them and see if they come back
dub-mike
« Reply #2 on: 22 June 2010, 21:21 »
already cleared once and they have come back so not sure what to try next?
jamie16v
« Reply #3 on: 06 October 2010, 20:01 »
i am also getting these faults too since putting in immo3 clocks. everything seems to work as they should though..
Offline DarkGti
« Reply #4 on: 06 October 2010, 21:11 »
god i wish i could fit immo 3 clock into mine! :drool: :drool:
jamie16v
« Reply #5 on: 28 December 2010, 20:04 »
sorry to dig one up, but wish i didnt bother with mine... not that i`m having problems..
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 28 December 2010, 20:09 »
I bet everyone wishes they could get their money back off you lol
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #7 on: 28 December 2010, 20:13 »
people still chasing for money ??
jamie16v
« Reply #8 on: 28 December 2010, 20:14 »
what am i missing?.. :grin:
Offline The Dave
« Reply #9 on: 28 December 2010, 20:22 »
Seen his car outside his house for first time in ages so god knows bout him lol
