Author Topic: other parts when running coilys  (Read 1077 times)
Offline paulturbo
« on: 21 June 2010, 13:01 »
as i am watching some coilys on fleabay at the mo, i was wondering other than replacing the top mounts with new ones, should i replace anything else like the drop links etc?
Offline Adam
Re: other parts when running coilys
« Reply #1 on: 21 June 2010, 13:04 »
If your going low you will need to replace the ARB or buy the adjustable drip link to clear the driveshaft, just remember you need to shorten the drop links if you go down this route.
Down Hill From Here.
Offline Rhyso
« Reply #2 on: 21 June 2010, 13:12 »
Don't you also need spacers if you're going silly low?  :undecided:
Steve has some to clear the adjuster ring is it  :undecided:
Offline Adam
« Reply #3 on: 21 June 2010, 13:14 »
True, I'v had to use 5mm spacers to clear the front adjuster ring.
Offline T_J_G
« Reply #4 on: 21 June 2010, 13:15 »
I think so depending on the wheels and ride height. My
mate is running 8 wide with no soacers up front IIRC
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #5 on: 21 June 2010, 13:31 »
also if your going low check the state of your front wishbone rear bushes, as when lowering it puts extra stress on these and will split. If they are worn upgrade to Audi TT Bushes or poly bushes ( Note poly bushes can give a harsh ride.)
