Author Topic: engine cover rubbing  (Read 3539 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
« on: 20 June 2010, 22:49 »
Oks my engine cover keeps rubbing against my pipe work and now its becoming a problem, i have to replace two pipes and its starting to damage the pipe work for the AC
1. What can be coursing it ? engine vibrating and possible fixes
thanks
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline godsANGER
Re: engine cover rubbing
« Reply #1 on: 21 June 2010, 14:23 »
any ideas?
Offline Rhyso
« Reply #2 on: 21 June 2010, 14:25 »
you on about your top engine cover?
Offline godsANGER
« Reply #3 on: 21 June 2010, 14:34 »
yep, should have probably stated that.
Offline Rhyso
« Reply #4 on: 21 June 2010, 14:38 »
you got any pics of your engine cover? and possibly a bigger pic of the bay?
« Reply #5 on: 21 June 2010, 15:23 »
can you not just trim the area where its rubbig? or fit some fabric tape to stop the chafing.  sounds liek the cover isnt fitted right if its rubbing on stuff though.  can you bend the a/c pipe retaining bracket a bit to move it out the way?
Offline godsANGER
« Reply #6 on: 21 June 2010, 16:36 »
ill get some, only one i have atm is this one, don't think it well be much help.
but you can see the two pipes at the top, one with yellow tape and one with red and just in view is the pipe at the front for the AC just popping up above the blue screwdriver.
I am hoping that's a last resort cutting the cover. the cover screws down fine i think it may just be the engine vibrating to much, can you tune the engine? or can the engine go out of sink or anything like that?
Offline godsANGER
« Reply #7 on: 21 June 2010, 18:49 »
The cover at the top had rubbed in to the pipe on the right Red and the pipe on the left Yellow is clipped on to the cover which has rubbed on the corrugated plastic the pipe below it.
the plastic is rubbing here. going to tape it up when i have a min
Offline Rhyso
« Reply #8 on: 21 June 2010, 19:24 »
weird  :undecided:
Can you rock the engine back and forth by hand?
Offline godsANGER
« Reply #9 on: 21 June 2010, 19:42 »
weird  :undecided:
nope, you thinking engine mounts ?
