Author Topic: toad Ai606 boot pop  (Read 2610 times)
jamrock
toad Ai606 boot pop
« on: 20 June 2010, 19:56 »
i have wired up my alarm to try and work a boot popper. I have used this diagram
http://www.fiestaguides.co.uk/images/boot_pop/big/01.jpg
then i trigger the boot pop the car locks. any idea what i can do to stop it from locking the car??
i am not using a switch at present, trying to pop it off the alarm
thanks
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: toad Ai606 boot pop
« Reply #1 on: 23 June 2010, 22:19 »
Could do with a bit more info here...
What car?   and what Alarm system etc..?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
jamrock
« Reply #2 on: 24 June 2010, 01:46 »
yeah might help :laugh:
on my mk2 golf
alarm is a toad Ai606
the car shouldnt lock when i trigger it. but when i do the car locks and to unlock it i have to arm it and then disarm it  :shocked:
Offline Rmachines
« Reply #3 on: 24 June 2010, 07:34 »
Ok, did you wire the whole alarm in your self or are you just adding the boot popper?
jamrock
« Reply #4 on: 24 June 2010, 11:21 »
did the whole alarm myself. there is a wire that when i hold down a button for 3 secs it turns positive. thats the wire i have been trying to connect my pop and relay to.
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 24 June 2010, 12:53 »
hhiya jamrock, i think the button your pressing is the total closure, is it the bottom right button? as that is the total closure (closes everything, the doors windows & sunroof if they elec. two things you could try, reprogram the alarm or try the bottom left button & keep it pressed see what happens with that. i have same alarm but no boot pop
*****MK3 Anniversary*****
*****MK4 GTI T*****
jamrock
« Reply #6 on: 24 June 2010, 12:56 »
cool will do. yeah i think thats the button.
