Author Topic: harness advice  (Read 46040 times)
Offline JonLeeper
Re: harness advice
« Reply #40 on: 22 June 2010, 15:42 »
What's you timescales, or is it (like mine) as and when i get round to it!  :shocked:
Offline leeroy20vt
  • h reg mk2 gti
Re: harness advice
« Reply #41 on: 22 June 2010, 15:51 »
well next trackday here is the 3rd of july so i amaiming to get the tyres on and lowered for that day then look at gettin cage and harnesses in for august hopefully  :smiley:
Offline Diamond Hell
  • Opinions я Us
Re: harness advice
« Reply #42 on: 22 June 2010, 16:00 »
Scaffold bar: made from any old shyte and rat droppings dug out of a chinese sh*thole.  Featuring a large, weak seam down one side of the tube.
CDS: Made from, errrrr cold, drawn steel, to proper specification.
Using scaf bar for cages is a VERY bad idea, never mind the weight implications.  Don't do it.  You don't know how it will deform or snap.
Plus cage tubing should be mandrel bent, really
HTHs
The price of Custom Cages (or any of the other start-ups from ex-CC employees) means you are probably better off just buying a kit.  Think about where you're cross-bracing it though - a vertical brace may not work if you're 6'ish due to the size of the passenger compartment.
Offline leeroy20vt
  • h reg mk2 gti
Re: harness advice
« Reply #43 on: 22 June 2010, 16:04 »
HTHs
wasnt goin to make this cage out of scaffold lol  but was just looking at normal steel tube
i found some 32mm cds 17 quid a metre  :shocked: :shocked: :shocked: :cry: :cry: :cry: altho still not thick enough for the blue book lol
mayby i will just look around for a second hand cage  :undecided:
Offline JonLeeper
Re: harness advice
« Reply #44 on: 22 June 2010, 16:08 »
HTHs
Good luck with that, I still can't find one!  Well not for reasonable miney anyway.  New they are about £350 - £500 and then you have to fit so not cheap.
Offline leeroy20vt
  • h reg mk2 gti
Re: harness advice
« Reply #45 on: 22 June 2010, 16:09 »
HTHs
looks like making it out the correct metal is still goin to be cheaper  :cry:
Offline JonLeeper
Re: harness advice
« Reply #46 on: 22 June 2010, 16:11 »
What's the price of CDS?
Offline leeroy20vt
  • h reg mk2 gti
Re: harness advice
« Reply #47 on: 22 June 2010, 16:16 »
only found one place so far £17 a metre i think its so dear cos its seamless as well but not 100% on that
and surely any sort of rollcage has got to be better than not having one ?
Offline JonLeeper
Re: harness advice
« Reply #48 on: 22 June 2010, 16:25 »
Amen to that.  How much tube do you think each cage has in it?
Offline leeroy20vt
  • h reg mk2 gti
Re: harness advice
« Reply #49 on: 22 June 2010, 16:33 »
wouldnt like to say mayby 15-20 metres  :undecided:
