Author Topic: harness advice  (Read 45993 times)
Offline leeroy20vt
  • h reg mk2 gti
harness advice
« on: 19 June 2010, 21:59 »
just got a cheap boat for the track (mk3gti)
once interior is stripped weres the best place to bolt harness down
cheers lee
Offline Diamond Hell
  • Opinions я Us
Re: harness advice
« Reply #1 on: 19 June 2010, 23:58 »
Dedicated, custom harness mounts and wrapped around the harness bar in the cage that you'll need to install before you fit harnesses.
NOT f*cking seatbelt mounts..... if you value your physical well-being.
Offline leeroy20vt
  • h reg mk2 gti
Re: harness advice
« Reply #2 on: 20 June 2010, 09:19 »
cheers dh trouble is wasnt goin to put a cage in for first outing just wanted to see what the boat would be like  :smiley:
but on same token wanted to be a little more strapped in than just a seat belt
  • Opinions я Us
Re: harness advice
« Reply #3 on: 20 June 2010, 09:32 »
Don't be an idiot and put in badly fitted harnesses, get one of these instead:
http://www.cg-lock.co.uk/
Spend the rest on a proper car-use helmet.
VeeDubGTI16v
Re: harness advice
« Reply #4 on: 20 June 2010, 10:02 »
have you got buckets? imo its worth fitting both if your car corners well enough for you to fall out your standard seat, so the bucket and harness give you more control. safety is a bonus tbh
Offline leeroy20vt
  • h reg mk2 gti
Re: harness advice
« Reply #5 on: 20 June 2010, 10:08 »
that looks like quite a tool
but i will only be using it for one day to see if its upto the job then it will have a cage ect put in
veedubgti16v
no standard seats at the mo i used to do oval racing so trackdays are goin to be a little different for me hence the cheapness start to it and dont want to go mad and chuck a rollcage and bucket seats ect for it
cheers for the info so far
VeeDubGTI16v
Re: harness advice
« Reply #6 on: 20 June 2010, 10:10 »
for the first day i would just drive it as it is, you will soon work out where money needs spending for the next one!
Offline leeroy20vt
  • h reg mk2 gti
Re: harness advice
« Reply #7 on: 20 June 2010, 10:11 »
ok kool just wanted to chuck a harness in so i didnt end up laying on passenger seat lol but if it safer to leave seatbelt in for now i will do that
VeeDubGTI16v
Re: harness advice
« Reply #8 on: 20 June 2010, 10:19 »
i found its more the seat that stops you moving around than the harness, so if you went for a seat and std seatbelt you wouldn't have to worry about the mounting points, and then maybe put harnesses in after a cage?
  • Opinions я Us
Re: harness advice
« Reply #9 on: 20 June 2010, 10:53 »
How big are you?!
I fitted Scirocco seats to my Golf2, which are damned fine.  IIRC there's a few SEATs with Golf3 width runners.  Might be worth having a poke about in a yard for one of those if the G3 seats really are that bad.
CG-Lock should cure the 'slopping about' problem though.....
