Author Topic: accelerator  (Read 1795 times)
Offline gti265
accelerator
« on: 19 June 2010, 13:09 »
hello all,
on my 2007 golf, when i puch the accelerator down it goes nearly all the way then stops, then if i push it harder it goes all the way to the floor, whats the reason for this??
tom
candy white 2007 golf gti, fully colour coded, tinted windows and black alloys :)
Offline Matt23
Re: accelerator
« Reply #1 on: 19 June 2010, 13:36 »
If you have a dsg gearbox it's the kickdown button. on mines its green button under the pedal.  :smiley:
Offline gti265
Re: accelerator
« Reply #2 on: 19 June 2010, 20:27 »
yer i do have dsg, so i have 2 push the pedal all the way down which makes it drop down gears anyway, to make it change down?? whats the use for it?
tom
Offline Matt23
Re: accelerator
« Reply #3 on: 20 June 2010, 19:36 »
Not sure as it changes down well before then anyway. It must have something to do with the flyby wire system it uses.
Offline Enforcer
Re: accelerator
« Reply #4 on: 23 June 2010, 22:10 »
In my e46 M3 (smg) there was similar system - going past kick-down dropped the gear to the most performance optimal. So sometimes I could be in 6th gear and on kick-down it would drop to 4th - as opposed to 5th on a gentle press.
I'd assume in principal the golf is the same - but not powerful enough to make the change so dramatic?
