Author Topic: clicking/tinking over small bumps  (Read 1273 times)
Offline Big Tone
« on: 19 June 2010, 12:38 »
As above, got a reall annoying clinking/tinking noise when going over small bumps,
checked exhaust (as it sounds like something is hitting that) and had a look round, couldn't see anything loose and dont really know where to look.
just wondered if anyone has had similar issues.
Will have a good search tomorrow, when I finally get a day off!
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Phil18t
Re: clicking/tinking over small bumps
« Reply #1 on: 20 June 2010, 11:04 »
is your golf lowered? if so could be the driveshaft tapping the anti-roll bar?
Offline Big Tone
« Reply #2 on: 20 June 2010, 11:58 »
No not lowered, all standard suspension.
Thinking Rear bushes as its nearly ten years old and most stuff is factory fitted
Offline mattGTI20
  • mattGTI20
« Reply #3 on: 20 June 2010, 15:22 »
Sorry to hijack the thread but my golf has been lowered and it makes this sort of noise but sounds like its coming from the front is this common cos of the driveshafts as said, if so is this bad for the car. cheers
Offline mattGTI20
  • mattGTI20
« Reply #4 on: 21 June 2010, 00:00 »
Bump
Offline rheady
« Reply #5 on: 21 June 2010, 13:57 »
Check the exhaust is not knocking on the rear. Mine was knocking the rear beam. You will see a shiny part on the exhaust if it is. Make sure the exhaust is cold though.
