Author Topic: Xenon H.I.D Lights  (Read 4963 times)
Offline IBD4vid
Xenon H.I.D Lights
« on: 18 June 2010, 02:29 »
hi if i have posted this in the wrong section sorry :(
I have a mk5 golf gti rep and it has a xenon hid conversion on there the only problem is that sometimes it plays up. when u turn it on the drivers light will come on then u flick back to side light and try again after a few tries both lights will light up. ( at time to time u will turn it on and drivers comes on then go to sidelights and back to main and the passengers side lights up but drivers doesn't.)
if anyone can help fix this or know why this is happening please let me know
cheers in advance  :smiley:
visit my car site www.mycarsevolution.co.uk
The GTI Rep Coming Soon
Offline AlanD
  • MK5 2.0T 16v
Re: Xenon H.I.D Lights
« Reply #1 on: 18 June 2010, 10:56 »
Sounds like the switch isn't making properly rather than a problem with the HID themselves.
I wouldn't know where to start with regards to replacing it.
Offline Adam
« Reply #2 on: 18 June 2010, 11:00 »
You need an HID relay kit, it provides the HIDs with a 12V source from the battery rather than pulling it from the headlight switch. - http://cgi.ebay.co.uk/High-intensity-Discharge-Lamp-HID-Relay-Harness-H4-/280519252098?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4150401882
I had the same problem with mine bought this and worked no problem.
Down Hill From Here.
Offline Colinv
  • Qualified VW mechanic
« Reply #3 on: 18 June 2010, 22:06 »
As said previously, a relay kit should
sort your problem out mate
« Last Edit: 18 June 2010, 22:09 by Colinv »
Offline IBD4vid
« Reply #4 on: 18 June 2010, 22:58 »
Thanks for the quick reply :) is this easy to fit?
Offline Colinv
« Reply #5 on: 19 June 2010, 09:01 »
I've never fitted one mate but I'd imagine you would get instructions with it. I also think off hand the mk5 headlamps are H7 bulbs rather than H4 but I may be wrong
Offline weston
« Reply #6 on: 19 June 2010, 11:33 »
Original headlight units are H7. Aftermarket ones can vary.
Offline IBD4vid
« Reply #7 on: 19 June 2010, 11:36 »
my hid lights r h7 i have found the kit now cheers guys :)
Offline Adam
« Reply #8 on: 19 June 2010, 12:56 »
Very easy to fit with the instructions provided :)
Offline IBD4vid
« Reply #9 on: 02 July 2010, 11:22 »
Hey all wonder if you could help i went and got this http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320552355367&ssPageName=STRK:MEWNX:IT   (H7 relay) but it never came with any instructions has anyone fitted one to there car that might be able to help?
