Author Topic: suspension 'spreader tool'  (Read 2471 times)
Offline wakeboarder15
« on: 17 June 2010, 20:19 »
hi guys
just read through a 'how to' on fitting coilovers and there is mention of a spreader tool
....which i dont have
so basically what can i use that will do the same job?
cheers
elliot
Offline Phil18t
Re: suspension 'spreader tool'
« Reply #1 on: 17 June 2010, 20:27 »
spreader tool??
Offline Lewisf1988-DUB
  • 1.8T AGU
« Reply #2 on: 17 June 2010, 20:28 »
Quote
VW Special Tool #3424 a.k.a. The Spreader Tool (required) - available for $10 from Autotech or $20 from Zelenda. Or, if that's not available, a 1/4-inch slotted screwdriver bit in a 1/4 ratchet drive can work too.
:smiley:
Offline Adam
« Reply #3 on: 17 June 2010, 20:31 »
A universal persuasion tool works well.
Down Hill From Here.
Offline EuanGtTdi
« Reply #4 on: 17 June 2010, 20:36 »
flat headed screw driver and a hammer  :grin:
  • 1.8T AGU
« Reply #5 on: 17 June 2010, 20:37 »
haha love it
Offline rheady
« Reply #6 on: 17 June 2010, 22:45 »
You'll need a f@@king strong screwdriver. Mine would'nt budge.
« Reply #7 on: 17 June 2010, 23:17 »
was it that bad :undecided:
might soak it in wd40 overnight!
and then give the old hammer and flat headed screw driver a go :grin:
cheers
elliot
Offline Purely VAG
« Reply #8 on: 18 June 2010, 05:30 »
Never needed to spread the hub carrier with coilovers. Needed when fitting OEM struts. Handy to have though, i need one myself.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #9 on: 18 June 2010, 08:48 »
just use a hammer and chisel to open it up
